Bottom Blueprinting >
Bottom Blueprinting
Bottom Blueprinting
Old 08-26-2003 | 06:03 PM
Elite Marine's Avatar
Default Bottom Blueprinting
A friend of mine was interested to know what speed gains and/or handling gains have been made by blueprinting the bottom of a 25' Thunder.
He's planning on putting a 550 HP motor and was interested in what results others have seen and if it is worth the cost.
Thanks in advance!
Kirk
Elite Marine is offline
Old 08-26-2003 | 07:44 PM
Vinny P's Avatar
I hate the winter!!
I can't answer your question, but I have heard that if you mess around with the bottoms, you can run into severe handling problems. I suppose you have to really know what you are doing to attempt this. Didn't MrGadgets have some handling problems a while back??
Vinny P is offline
Old 08-26-2003 | 08:42 PM
Payton's Avatar
Charter Member #927
I think it depends if he has a problem with his bottom now.
Payton is offline
Old 08-27-2003 | 06:54 AM
boatfreak's Avatar
Payton, I think they have doctors for that.
boatfreak is offline
Old 08-27-2003 | 07:21 AM
Payton's Avatar
Charter Member #927
Awe, head south you farmer.
Have a good week Mike.
Payton is offline
Old 08-27-2003 | 07:30 AM
Scott's Avatar
Charter Member #30
Take a long straight edge and look for hooks. If they are there because of a manufacture error or sitting on the trailer wrong they will slow the boat down. If it was built in on purpose from AT then it more than likely is making the boat safe or a fix for a time to plane problem.
What can be done without changing the hull design is to sharpen the trailing edges on the "on plane area" of the bottom. This will allow the water to leave the surface faster and increase the speed by ???????? I doubt if it would be worth it unless you had to squeak out 1 mph to win a race!
This is just my opinion and observations from my own experience and a lot of research I am NOT an expert
I have Steps & Bubbles!
Scott is offline
Old 08-27-2003 | 08:24 AM
32storm's Avatar
It all depends what the bottom is like when you start. It involves blocking wetted surface, adding gel to low spots if required, & sharpening edges.
I had mine done a couple of years ago. Did not effect handling at all and net gain was zero MPH.
However, some boats have picked up as much as 5 MPH.
It all goes back to what your bottom is like when you start.
32storm is offline
Old 08-28-2003 | 08:47 PM
In the boat you are dealing with, "blueprinting" could be a real factor! Scott's advice is real good. Make everything as true, flat, and crisp (edges) as possible, then install some decent tabs to control "flight" and enjoy your "new" boat. --- Jer --- p.s. I picked up well over 5 mph.
jpclear is offline
richsformula
Detailing, Painting, & Fiberglass
35
05-05-2024 12:50 PM
sleek1
04-25-2006 01:47 AM
exaeh007
18
07-07-2005 05:02 AM
open87
03-17-2003 03:12 PM
TJP
Superboat
12
02-04-2002 11:44 AM
