272 anchore locker >
272 anchore locker
272 anchore locker
Old 09-25-2003 | 04:50 PM
Boss 69's Avatar
Default 272 anchore locker
Any body have any eperience with the drain in the loker clogging and not draining. If so how did you fix?
Thank You
Boss 69 is offline
Old 09-25-2003 | 10:39 PM
DJW's Avatar
DJW
I kept rodding it out with a clothes hanger and I cannot remember if that ever solved it.
DJW is offline
Old 09-26-2003 | 11:48 AM
Luv-N-It's Avatar
I had the same problem. I inspected mine really close one day and removed the drain plate and it was plugged with caulking/silicone.
Also, do a search on this subject in Baja or check back through previous threads. This has been an issue with other 272's also.
Luv-N-It is offline
Old 09-27-2003 | 06:53 AM
jafo272
I read somewhere that you can pull a front cuddy speaker out and reach all the drain lines
Old 09-30-2003 | 11:38 AM
Macklin's Avatar
Had the same issues with my 272. You only need to pull the speakers for access. It is not easy getting in through the speaker openings, but doable.
Macklin is offline
Old 10-01-2003 | 03:04 PM
jrz
I used about 25psi through the opening in the hull.
jrz is offline
Old 10-01-2003 | 04:23 PM
Boss 69's Avatar
Thank's every one I'll try all and let you know what works
Boss 69 is offline
Stalkin
Cigarette
6
04-02-2007 09:07 PM
kjm5125
04-19-2006 08:45 PM
JasonSmith
Baja
4
12-31-2005 10:13 PM
DayTripper
Baja
3
09-23-2005 01:18 PM
Advantage
Baja
7
04-26-2002 07:37 PM
