merc sea pump/fuel pump
Originally posted by monza24
can i run a high volume fuel pump with combo. if so what pump do you suggest. motor is 540 with holley hp 950
KCHOBOAT,
Which Carter pump did you get? I presume you bought the Carter HV pump, then only used the bottom half of it and bolted it to the top half of the merc belt driven pump?
I see that CP Performance sells a bottom half kit for the merc pump, but in my opinion overpriced at $150. I would guess that the entire Carter HV pump you are talking about was under $100??
Originally posted by 35/25
KCHOBOAT,
KCHOBOAT,
Thanks for the tip.
Is there a particular Carter HV pump # that you recommend? What is the estimated gph of the new combination pump?
Also, I know that a conventional mechanical pump won't work on the merc belt-driven setup, but never knew what the difference was. Is the pump arm different or what?
Rich
Rich
The pump arm is different. Holley also makes a marine mech pump that will bolt up to the merc arm. I use them with my twin-750s and they hold pressure fine..
Steve Gresham
'03 Donzi 33ZX
Steve Gresham
'03 Donzi 33ZX
BillR
11
07-29-2022 06:31 AM
