Go Back  Offshoreonly.com > Owners Forum > Sunsation
X dimension help please, 24' Rocket >
Old 09-30-2003 | 12:31 PM
Default X dimension help please, 24' Rocket
A friend and I recently purchased an older (1993) 24' Sunsation. The boat was originally built as an "A" class raceboat. The boat had an OMC King Cobra outdrive, which is being replaced with a Bravo I. My question is: what is the X dimesnsion for this boat. Currently the centerline for the prop shaft is 7" below the bottom of the pad. The drive looks too deep to me. If someone could measure the bottom of the boat (pad) to the centerline of the prop shat, I would appreciate it!
Eventually we would like to run in P5 or A class.
Thanks for your anticipated response!
Bob G.
Fast Shafts is offline
Old 09-30-2003 | 12:46 PM
Aggressor 25's Avatar
I have a 2001 Aggressor with a Imco SC 2" shortened drive. I can measure my X tomorrow evening. With the shortened drive I have marked neutral position on the mechanical indicator and can only trim just over 1 position above. I am using a lab finished Bravo 1 prop. Before with stock power a Mirage worked best with the deep X.
Aggressor 25 is offline
Old 09-30-2003 | 08:32 PM
Bob,
I left your partner a message about 5:00 pm today.
My X dim. is about 8".
Ray
raynman is offline
Old 09-30-2003 | 11:19 PM
Ray, Aggressor,
Thanks for the responses.
Ray Congratulations on your 2nd place finish in Cambridge! I hear you almost pulled off a major upset! Are you going to do St. Pete?
We're hoping to get the boat in the water this weekend-if all goes well.
Bob G.
Old 10-01-2003 | 02:38 PM
DaveSunsation's Avatar
Robert,
Wayne knows the boat you're talking about, he set that x dimension originally 1" higher than normal and says you should be able to put the bravo on as it is and be fine. If you have more questions, pleaes feel free to call us.
810-794-4888
DaveSunsation is offline
Old 10-01-2003 | 02:46 PM
Thumbs up
Thanks Dave,
We'll be testing this weekend.
Bob G.
Old 10-03-2003 | 07:37 PM
Bob,
Thanks. The old Rocket ran good in Cambridge. Everyone we talked to said we looked good. I don't know how far back we finished but we were closing at the end. We will be in St. Pete. Are you going to be there?
raynman is offline
KN
05-24-2022 04:51 PM
Air Dog
09-23-2009 11:24 AM
phughes69
Sunsation
4
12-06-2007 01:50 PM
Dregsz
Cigarette
4
03-10-2006 03:54 PM
Fast Shafts
Sunsation
2
01-14-2004 09:04 AM
