Fuel Pressure (Carbed motor) ??
I have a blown carbed 454 using the stock fuel pump and also an electric holley (helper) pump. I dont have a regulator at the carb. My dash mounted pressure guage has always read about 8 lbs. or press. Now all the sudden it is climbing as i push the throttle. Goes up to 15 lbs. Could the diaphram in the stock pump be going and creating the extra pressure??? Or do you think i may have a short somewhere in the wiring to the gauge?? The motor still runs fine and is not giving me any fuel related problems.
I have a spare stock pump that i was thinking of putting on to try, but i thought i would ask here before wasting my time.
You'll blow the floats off the seats at 12psi and it will run all blubbery. If shes running normally, then I suspect you have a problem with your pressure sender or pressure gauge or in the wiring or ground to them.
Well , the electric feeder pump doesn't know about rpm ,it just pumps. The mechanical pump should be rpm sensitive. Is your regualtor before or after the mech. pump?
I used Carter pumps with internal regulators and run 8 to 9 lbs on the dash guages.
Perhaps a bad regulator
If you can make it do it just by hitting the throttle(sitting still) try a mechanical pres. guage at the carb. That should varify the accuracy of your dash guage.
Originally posted by mopower
Well Is your regualtor before or after the mech. pump?
