Tow vehicle failure >
Tow vehicle failure
Tow vehicle failure
Old 01-24-2002 | 04:41 PM
fishon
Post Tow vehicle failure
1996 Dodge Ram 1500 w/positraction 2WD 360 v-8. 76k miles.
Just replaced the pinion gear bearings in the rear axle ring/pinion gear set. Appears one roller bearing failed and fragments scored the remaining roller bearings. Could this be a towing related failure, lube failure or bad luck ?
Almost as expensive as a lower unit gearset repair !!!
Old 01-24-2002 | 04:54 PM
traviss's Avatar
Post
chuta bauta chevy
traviss is offline
Old 01-24-2002 | 04:57 PM
Cattitude's Avatar
Post
The Chrysler 9.25" is pretty tough and substantialling bigger than chevy's 12 bolt they use in 1/2 tons. I'd ask the shop how often they see this problem- I suspect it is a fluke. If you do tow often/heavy it would be wise to change the gear oil more often and use a good sythetic. The bigger Dodges use synthetic from the factory. Good luck!
Cattitude is offline
Old 01-24-2002 | 05:10 PM
250 sport
Post
My dad had the same thing happen with a 96' Dodge Ram at 45000 miles. It happened on a trip to the lake towing a 22' Checkmate.
Old 01-24-2002 | 05:55 PM
Smitty's Avatar
Post
Pretty normal problem with any brand if alot of towing is done with 1/2 ton truck. My Chevy pinion just gave out at 60k almost all towing miles. Bigger trucks have bigger rearends and bearings etc. Just remember to do frequent lube changes to prolong life.
Smitty is offline
Expensive Date
Fountain
14
11-25-2006 08:15 PM
THEJOKER
05-25-2006 03:22 PM
mcraymond3
03-30-2004 07:40 PM
aTX427
Fountain
9
10-07-2003 12:19 AM
Niuhi
05-09-2002 06:53 PM
