block heaters >
block heaters
block heaters
Old 01-14-2004 | 11:14 AM
stecz20's Avatar
Default block heaters
for all you guys that live in the cold states, what do you use for block heaters. i bought some pipe heaters zip tied them to some copper pipe, and went 5ft in from the tips. this ----- cold is making me nervous. what do you guys do, besides send to florida?
stecz20 is offline
Old 01-14-2004 | 01:52 PM
stecz20's Avatar
of course the rig is winterized. must be some type of block heater for boats.
stecz20 is offline
Old 01-14-2004 | 04:40 PM
KCHOTBOAT's Avatar
Charter Member #737
They make magnetic and ones that replace a freeze plug. A friend of mine ran one to keep some temp on his oil because of problems with a cold start and his blower. I know his was an automotive one.
KCHOTBOAT is offline
Old 01-14-2004 | 05:11 PM
DanB's Avatar
Charter Member #71
Seems like I've heard of one that goes down the dipstick tube...diesel engines need em to keep the oil warm....but down here we dont use em
DanB is offline
Old 01-14-2004 | 07:02 PM
Theres a unit that replaces a freeze out plug (Don't know how it will stand up in salt water), a magnetic one that sticks to your oil pan, a dipstick one that goes...well you know where, and an inline one that would normally go in a radiator hose (Probably good on a closed system). If it's winterized, why bother? Do you want to start it up in this cold??? Check JC Whitney, they have all that stuff. They even sell one that you can stick to your battery!
Liberator21 is offline
Old 01-14-2004 | 07:21 PM
Steve H's Avatar
artselectricinc.com
I just use a little 1500w heater. Set it at about 60 on low watt setting. Keeps everything dry and warm. starts alot better too.
Steve H is offline
Old 01-15-2004 | 08:12 AM
Crazyhorse's Avatar
You can buy a silicone pad heater that adheres to the oil pan. I've used them before and they work very well.
Crazyhorse is offline
deboatmon
12-05-2005 12:29 PM
xtremeheaters
New Products and Member Discounts
0
09-29-2005 02:42 PM
gripit
Cigarette
3
10-18-2004 09:42 AM
Cigwillie
01-04-2004 08:15 AM
