NE 1 use an alum. intake manifold in SW??? >
Old 01-20-2004 | 06:48 AM
bowtie89
Default NE 1 use an alum. intake manifold in SW???
I found a nice hi rise intake manifold from edelbrock only its aluminium people to me I could use it if I flush after every use in Salt Water!! I trailer the boat so it doesn't see any significant amount of time sitting in the saltwater!! Never overnight!! How long do you guys thing one would last?? 1 year 2, 3...
Does anyone here use one?? I have gotten different opinions on this subject!!
Old 01-20-2004 | 07:02 AM
Payton's Avatar
Charter Member #927
There is at least one guy here on the board that runs aluminum blocks, in the Pacific, all the time. He flushes with Salt Away after every use.
I think he told me he is going on 5 years now.
Payton is offline
Old 01-20-2004 | 07:06 AM
SS930's Avatar
I've often wondered the same about aluminum heads if taken care of in the manor posted above.
SS930 is offline
Old 01-20-2004 | 07:11 AM
cuda's Avatar
I have aluminum Merlins on mine now. They have been on there two years, but they scare the chit out of me. I'm looking now for the bronze lined intakes. A buddy of mine lost an engine due to aluminum intakes.
Here is a picture of Mercruisers first attempt at EFI. They were made with aluminum intakes. This one got a hole and that was the end of the engine. It had been repaired in this picture. It is circled in red.
cuda is offline
cuda's Avatar
Here are the results of a failed intake.
cuda is offline
Old 01-20-2004 | 07:50 AM
mcollinstn's Avatar
bowtie,
you CAN run alum intakes, but there are good iron intakes available for your sbc.
If you do plan to run an alum intake, then beadblast the water passage out, and coat it with several applications of epoxy. THEN still flush after every use.
mcollinstn is offline
Old 01-20-2004 | 08:08 AM
bowtie89
Default how do I?
how do I go about coating it with epoxy just brush it all around the water passage!!! or is there some other trick???
Jassman
Active Thunder
20
10-01-2007 08:45 AM
drewwilliams
9
05-05-2006 07:49 PM
cloudmaster_321
27
05-01-2005 09:45 AM
fulloblarney
9
06-26-2004 12:06 AM
bowtie89
01-15-2004 02:18 PM
