Scarab I Deck Hatch >
Scarab I Deck Hatch
Scarab I Deck Hatch
Old 02-03-2004 | 09:43 PM
sid
Default Scarab I Deck Hatch
I am looking for any and all advice on installing a deck hatch on my 1985 21 Scarab I. The boat is in excellent original condition. However, I believe the cabin would benefit greatly from the increased sunlight and ventilation afforded by a hatch. More specifically, would a centerline hatch diminish the structural integrity of the boat? Moreover the deck at the centerline is not flat. Please advise.
Old 02-03-2004 | 10:03 PM
homan
why not a small one on each side
Old 02-04-2004 | 11:24 AM
I had a friend with a 1986 scarab I with a center mounted deck hatch. His came like that from the factory. It was wide enough to drop straight down through with an adult sized body. If I remeber it was still very tight in there and had a built in cooler in the center so you had no step down for cabin ingress and egress from cockpit.
Vmax is offline
Old 02-04-2004 | 11:43 AM
Iggy's Avatar
Insted of one on center, how about two smaller hatches? One on each side.
My Formula offered two small hatches as an option on my F-206. The wood backing frames were glassed in under the deck during construction but I don't have hatches installed.
Iggy is offline
Old 02-04-2004 | 12:54 PM
THe bigger scarabs reinforce the coring with plywood around the hatch cutouts. You may end up with a lot of cracks in your deck if it's not strong enough.
Gary
Gary Anderson is offline
Old 02-04-2004 | 10:03 PM
sid
Thanks for the advice. I like Homan and Iggy's suggestion of two small hatches. At this point, i will probably install two 10 X 10 Bomar Hatchs. That should give plenty of ventilation and sunlight. However I am still concerned about stress cracks. Even though the boat is almost twenty years old there are no cracks on the deck now.
mjb
Cigarette
4
09-20-2008 06:41 AM
SeaWeasel
Fountain
0
08-04-2008 10:04 AM
jody165
07-24-2007 09:46 AM
MILD THUNDER
04-03-2007 12:12 PM
kennyo
Baja
2
04-03-2007 11:50 AM
