View Poll Results: What to do?
Replace Block only. 350ci
9
7.76%
383 short block
39
33.62%
420 short block
8
6.90%
434 short block
6
5.17%
502HP Big Block
54
46.55%
Voters: 116. You may not vote on this poll
Engine Options
Old 02-04-2004 | 02:13 PM
Kent Perroux
Default Engine Options
Cracked block, and need to change it out. I was looking at short block options also. Should be an interesting Poll. The least expensive will be the 1st option and going up from there.
Boat is a '83 Donzi Classic 18'. 350ci engine pushing 350hp. Bravo 1 Drive " higher x-dim than standard
Getting 70@5000. It will do close to 75 if I want to push the rpms.
If I go the short block route, I have heads, intake, carb, cam to match the flow needed. Stringers are HD and have External hydraulic steering.
Yes, I want more speed but want to maintain good handling.
Old 02-04-2004 | 02:28 PM
Kent Perroux
18 classic
Bravo 1 Drive, 2" higher X-dim than Donzi Standard.
Old 02-04-2004 | 02:41 PM
Biggus's Avatar
I love the Donzi Classics and have owned many over the years. Fun little hot rods.
If it was mine I'd put a HP500 in it......
Just because it will fit
Biggus is offline
Old 02-04-2004 | 02:42 PM
CAP071's Avatar
Get the best you can afford!
CAP071 is offline
Old 02-04-2004 | 02:43 PM
Biggus's Avatar
...and if you run aluminum heads and CMI's it wont weigh much more than the stock 260 Merc with all the cast iron junk.
Biggus is offline
Old 02-04-2004 | 03:09 PM
OldSchool's Avatar
Cool
There is no replacement for cubic inch displacement!!!
OldSchool is offline
Old 02-04-2004 | 03:21 PM
Official OSO boat whore
I'd stick with a small block in the 18. I'd go with a 350 mag set up for a blower or maybe the merc scorpion if you have the $$.
Cord is offline
Old 02-04-2004 | 03:22 PM
Airpacker's Avatar
go big or go home
Airpacker is offline
Old 02-04-2004 | 03:28 PM
Kent Perroux
Current engine...
Old 02-04-2004 | 03:37 PM
PatriYacht's Avatar
Go with a large c.i. small block. 406 is pretty easy. With World Products stuff 427c.i. / 500hp is not too expensive and all of your accessories still fit.
PatriYacht is offline
