New motor --- need help from the pros >
Old 02-05-2004 | 09:31 AM
aTX427's Avatar
Default New motor --- need help from the pros
I plan on building a new 540 Whipple charged motor for my 25 Daytona and would like advice on crank / rod selection. I expect to run race gas and build 900-950hp. 9:1 compression / 10# boost. I realize that I can just select top of the line parts without worries, however I don't necessarily want to overkill the the internals if I do not have to. BTW, I will be selling my complete long block HP500EFI (Pan to flame arrestor (no accessories or exhaust) if anyone has interest.
Choices are:
1. eagle/eagle
2. callies/manley
3. crower/crower billet
4. other???
Here are the components that I have selected so far:
Super Charger - 3.3 liter intercooled EFI Whipple
Block - Dart Big M w/ billet caps
Heads - AFR 335/121 CNC port
CAM - Crane 651
Pistons - JE flat top
Oil Pump - Moroso pro billet
Thanks in advance
aTX427 is offline
Old 02-05-2004 | 10:04 AM
rmbuilder's Avatar
MarineKinetics
Hard to overkill internals @ 950 HP
Moldex/Bryant.../Carrillo
Bob
rmbuilder is offline
Old 02-05-2004 | 10:51 AM
Official OSO boat whore
If you are buying the blower from Dustin, I betcha he could pick all the parts for you. For this motor, I would not be using any eagle parts. Also, do a search under the tech section for a thread on the new AFR heads. It was very interesting.
Cord is offline
Old 02-05-2004 | 12:05 PM
Reed Jensen's Avatar
CAllies/carillo/ J and E/ Manley Stainless intake Inconel exhaust... good stuff.
Reed Jensen is offline
Old 02-05-2004 | 01:26 PM
I would not use the Moroso Billet oil pump. The small screws that hold on the pick-up are a weak point. My pick up cracked and I threw the Moroso pump out.
BenPerfected is offline
wstultz
5
09-18-2006 06:32 AM
traviss
03-21-2004 08:09 PM
Jan
11-23-2003 06:31 AM
Montauk Crossbow
11-25-2002 08:07 PM
