Will   XR Drives fit on a  ? >
Old 03-07-2004 | 07:36 AM
cougarman's Avatar
Default Will XR Drives fit on a ?
Will it fit on a standard bravo 1 Transom Assembly ?
Also is the Drive any longer or shorter than the
standard bravo 1 ?
This is for a single engine 29' Power Quest
with a 540 ci in it. I don't think the power
is as hard on the current Bravo as the weight
is.
Thanks for any help.
Cougarman
cougarman is offline
Old 03-07-2004 | 07:58 AM
zt260's Avatar
Yes it will, but you must change the gimble bearing. (The new one has a red dot on it.) Other than that the drive will mount up fine and it is the same size.
zt260 is offline
Old 03-07-2004 | 11:43 AM
P Offshore's Avatar
Xr upgradeclick here
P Offshore is offline
Old 03-07-2004 | 04:30 PM
Be sure to put a good drive shower on it. Those straight cut gears run hot.
BadDog is offline
Old 03-07-2004 | 05:01 PM
You also need to put a spacer in the trim cylinders to prevent U -joint from binding in the event you ran the engine in trailer position. The trim cylinder end cap is removed and a small plastic spacer is inserted to limit the trim up. Merc has a PN for the whole kit, gimble bearing, seal behind gimble bearing and limit for the cylinder. There may have been a piece for the bellows, can't remember but it had to do with clearance for the larger U-Joints.
BadDog is offline
Rebel_Heart
Prop Talk
2
05-22-2007 08:59 PM
Dean Ferry
11-27-2002 08:09 AM
Hot Boat
7
01-09-2002 01:16 AM
