Proper K-Plane Mounting >
Old 02-02-2002 | 04:29 PM
Shooter's Avatar
Charter Member #300
Post Proper K-Plane Mounting
I mounted 110s kplanes on my boat after I riiped the cheapo Bennets off by a bad landing off a wave. I think I mounted them too low. What distance is usually left from the plance seat to the bottom edge of the transome. My first project of the spring my be to remount them.
Shooter is offline
Old 02-02-2002 | 04:50 PM
turbo2256
Post
My template shows 7/8" from lower plate to bottom of the boat
Old 02-02-2002 | 05:01 PM
Post
Mine are 1" above.
cobra marty is offline
Old 02-02-2002 | 05:02 PM
traviss's Avatar
Post
Mine are 1" above the bottom
traviss is offline
Old 02-02-2002 | 05:28 PM
turbo2256
Post
Actualy the distance can very from boat to boat actual dialing in buy factory is best mine are flush on port side and about 1/2 or 3/4 on the other. Its to comensate for torque thrust with a 7' beam
[ 02-02-2002: Message edited by: bopp ]
Old 02-02-2002 | 07:34 PM
Audiofn's Avatar
Charter Member #232
Post
mine are 1" up from the bottom. If you put them to low they tend to grab at that water and sprey all over the place.
Jon
Put your best foot forward!
Audiofn is offline
Old 02-03-2002 | 10:16 AM
Shooter's Avatar
Charter Member #300
Post
I think I only have 1/2 inch. I put them in the original bennet locaiton. If I trim all the way up, I'm sure they drag. I am sure that even when I trim them "even" thay still scrub off a couple mph.
Even though my Baja is considered a tub on the board here, I should be seeing more speed with a blown 454 in it... I get 72mph at best with a Bravo 1 26 labbed. Handles great, though.
[ 02-03-2002: Message edited by: Shooter ]
Shooter is offline
rtaylor
09-08-2008 03:59 PM
Dave M
6
11-08-2004 08:50 PM
blue64drop
6
11-11-2002 11:46 AM
blackhawk
09-11-2002 01:45 PM
NEVRENUFF
5
06-02-2002 01:10 PM
