Bravo 1 unit won't go down >
Old 04-25-2004 | 03:21 PM
Default Bravo 1 unit won't go down
I have twin bravo 1 drive units with lathem hyd. steering. One of the drives wont go down but the trim sender sounds fine just wont engage. These are brand new drives on a 04 when I put it away last week all was fine any info would be great. Thanks
thosetwins is offline
Old 04-25-2004 | 06:20 PM
alot of twin engine boats have a switch for starboard and port drives, in my 32 active thunder they are under the rear seat.
rssteiny is offline
Old 04-25-2004 | 06:41 PM
when you say switch a manual override switch kinda of like a transom switch. if i don't could it be a solenoid the trim still humms when you hit it it just wont go down with the other drive thanks
Old 04-25-2004 | 10:37 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
What do you mean trim sender sounds fine but won't engage? The sender is the round black cap on the pivots of the outdrives. Do you have mechanical or electrical trim indicators?
I assume you mean trim pumps..... Mounted in the engine compartment. No manual overide switch. There will be reset breakers, but it sounds like you have power do to the humming.
With the boat being a new '04, Best to let the dealer fix it under warrrenty
US1 Fountain is offline
Old 04-26-2004 | 08:40 AM
outlawinil's Avatar
If its an outlaw do you have both battery switches on?
I found out that one switch and battery controls the port side engine and outdrive and the other side controls the starboard.
outlawinil is offline
Old 04-26-2004 | 08:45 AM
Yes it is , but i think it is a valve stuck in the trim pump that wont let it go down since the trim still cycles it just wont go down. Thanks
Smitty
Swap Shop
10
03-26-2012 10:18 PM
trader1
07-29-2003 10:19 PM
maverick1
2
05-22-2003 05:57 AM
pmcrespo
Fountain
3
05-29-2002 12:49 PM
HiPerf2000
04-29-2002 04:54 PM
