Fuel pump replacement procedure >
Old 05-12-2004 | 07:26 AM
Dave M's Avatar
Veteran: Navy
Default Fuel pump replacement procedure
I am going to replace my mechanical fuel pump on my 454 Mag. It sits on top of the sea water pump. There is a gasket between the two. Do you put any kind of sealent on that gasket like permatex? Is there any other parts of this job that I need to know about?
Dave M is offline
Old 05-12-2004 | 09:32 AM
Jerry B
You can put some sealer on the gasket if you need to. It will help hold the gasket in place during instalation. Dont use very much. Make sure the lube oil in the sea water pump is not containamated by fuel. If the diaphram has gone bad in your mechanical pump it probably will be and will need to cleaned out and new added. It uses the same lube as your outdrive. Also be sure to clean up any spilled fuel. If you have a fuel shut off you might want to turn it off. Sometimes slight pressure can build in the tank which would keep force fuel out of the feed line.
Good luck.
Jerry B is offline
Old 05-12-2004 | 09:53 AM
Dave M's Avatar
Veteran: Navy
Thanks Jerry,
How about the rod or mechanism that drives the fuel pump? I haven't taken the old one off yet and not sure what to expect in there. I do know that the lube in there is contaminated because it is leaking out of the little weep hole.
Dave M.
Dave M is offline
Old 05-12-2004 | 12:49 PM
It's just a rod that runs off a lobe on your cam. The cold oil usually holds it in place but if it falls out there are no complex springs or anything. Watch when you remove to see the relationship with the lever on the fuel pump,install that way.
cooltoys61 is offline
Old 05-12-2004 | 12:54 PM
DAVE WHATZ UP? IS THE FUEL PUMP BELT DRIVEN OR ATTACHED TO THE SIDE OF THE BLOCK?
z.zuperboat is offline
Old 05-12-2004 | 01:21 PM
Jerry B
There is no rod driving this pump. There is a lobe, "Ecentric" made on the shaft that operates the pump. Just make sure the lever on the pump goes under the correct side of the lobe. Not to hard to see how to install it. I'm not sure you could install it incorrectly and be able to tighten the bolts. With the drive belt off you can turn the pulley by hand, Make sure you turn it the proper direction or you could damage the water pump, and you will feal a slight vacume coming from the inlet side of the pump. You might have to wrap a rag around the pulley and grip it with some vise grips to turn it. When you feal the vacume you know it's on right. But like I said. I dont think you can put in on wrong.
This pump is belt driven. Has water pump and fuel pump both driven by same belt.
Jerry B is offline
Old 05-12-2004 | 06:52 PM
Pat McPherson's Avatar
Dave,
May I make a suggestion?
Well I will anyway...
If your sea pump impeller has not been changed this year or last, change it too. They should be changed every two years if used in salt water; can stretch it to three if you run in fresh.
The impeller comes in a kit with a new plastic housing and is a vary easy job.
Good Luck Dave...
Patrick
Pat McPherson is offline
Old 05-12-2004 | 09:32 PM
Jerry B
Good idea Pat. I should have thought of that.
Jerry B is offline
Old 05-13-2004 | 06:06 AM
Dave M's Avatar
Veteran: Navy
Thanks Guys, I did order a new impeller kit that is going in too.
Dave M is offline
BillR
11
07-29-2022 06:31 AM
BillR
0
04-09-2008 07:07 AM
PROMAN
0
06-25-2007 07:50 PM
East Coast B
13
10-24-2005 10:50 AM
