Exhaust silencer
Exhaust silencer
Hi my question is does a silencer steal horsepower i have an 350 mag mpi wich is silenced. What do you think of the noise inside the boat when running at cruising speed unsilenced.? I have heard boats unsilenced and they sound a lot when standing on land. Still the sound from a v8 engine is really awesome. Maybe i should mention the exhaust is above the water.
All The Best Jon
All The Best Jon
My previous had a 550hp 454" with Lightning headers.
It was very very loud behind the boat, but you could have a conversation with out
shouting inside the boat at cruising speed.
May be the swim platform did a lot to keep the noise down,
I had a checkmate with a 350, and thru-hull exhaust like yours. Very loud behind the boat, and pity the person trying to ski or tube behind you. I bought a pair of slip in type of mufflers, you put them in right thru the back of your pipes. They wont make it a whole lot quieter, but it did cut down on the loud rapping that you hear when you are on shore at the marina.I never really noticed any loss of power with them. But what was nice ,is on those days when you wanna hear it all, it only takes a minute or so to remove them, by removing the single screw that hold them in. Less than 100 bucks for them... My .02
All The Best Jon
All The Best Jon
It all depends on what type of silencer your are talking about for your mod a diverter with a wishbone will work best. Remember you can only run thsese types of systems at idle through your harbour and marina.
These types will not rob you of any horsepower.
Hi please explain what a wishbone is i tried to check out the link you posted but the site is down for now. If i understand you guys it is best for the performance just to let out the exhaust unsilenced, am i right ?
If you run diverters otherwise known as silence choice exhaust when you engage the flappers they divert the exhaust down the wishbone and exits through the prop. The silent choice exhaust when not activated covers the wishbone exit and send the exhaust through the tips.
Here is a picture of the wishbone.
Right, you will get your best performance when the exhaust is unsilenced, however, remember the silence choice method is only for idling around the marina. My buddy has them on his boat and it is nice when you need to hear inside the boat and have a conversation.
