engine hatch wont open >
Old 05-23-2004 | 06:30 PM
Default engine hatch wont open
how do you get your engine hatch open if the electric lift is bad.
i have a 2000 32 active thunder, i hit the hatch switch it started to go up and quit, fuse is ok switch is ok must be in the engine compartment how do i get to it.
thanks 32 thunder rick
rssteiny is offline
Old 05-23-2004 | 06:40 PM
cuda's Avatar
Default Re: engine hatch wont open
On my Formula, the hatch will open far enough to unbolt it from the lift. Just lift on it.
cuda is offline
Old 05-23-2004 | 06:51 PM
I replaced the bolt that holds the hatch to the ram with a polished pin and a circlip to hold it. One end of the pin has a cable attached which is routed to the side vents. Four screws and the the side vent comes off, pull the cable and it is free. In your case it is a little late, upholstery surgery?
BadDog is offline
Old 05-24-2004 | 02:08 AM
Hey Rick,
What length is your hatch actuator? The one in my boat is a 18". I just bought two of them and I'm removing the old one which still works.
Did you get to your actuator yet? When you do measure from the center of the shaft hole to the center of the base bolt hole when it is all the way closed, that is your length.
Can you get to it through your vents? Even if you have to use some long ratchet extensions to reach the bolt. You may consider going in through your bench as well.
Needs some help give me a call.
Mike
Active Mike is offline
Old 05-24-2004 | 12:53 PM
Krumbsnatcher's Avatar
Too much damn work, hot wire your hatch switch with a battery jump from a charger on another battery, hence the motor only knows power, the power is missing so supply the power from your switch.
Bada bing your good to go!
Krumbsnatcher is offline
Old 05-24-2004 | 06:48 PM
MACDAD260's Avatar
Charter Member #818
Good idea BadDog,
That is almost exactly what I did to mine. The only difference is I used a rubber grommet to keep the pin from falling out on it's own. With the original 1/2" stainless bolt held in by a nylock nut there is no way in H*ll that the hatch could be opened on my Baja if the ram quit working.
Anyone reading these posts should think about this and do whatever is needed to be able to get the hatch up in the event of a ram failure.
MACDAD260 is offline
Old 05-24-2004 | 08:37 PM
McGary911's Avatar
Another decent tip is to mount some remote battery terminals somewhere out side of the engine bay. I have a storage under the back bench, and have a red and a black post in there wired to the batteries. Plastic covers on them. If the battery dies, i can still hook up some jumper cables and open up the hatch.
McGary911 is offline
Old 05-24-2004 | 08:49 PM
No access panel in the storage area under your rear seat? You would think a 2000 model would make provisions for this problem. Way to go Active Thunder. Bad dog has a great solution once you get it open.
red thunder is offline
Old 05-24-2004 | 11:36 PM
The problem is if the motor took a sh@!*t then jumping the power isn't going to help.
I'm installing quick realease pins in place of my top bolts which can be reached by the side vents.
Old 05-25-2004 | 10:02 PM
Most Of Them Will Lift Off The Actuator When It Is All The Way Down. It Only Locks In When It Starting To Go Up. Try Lifting It, It Takes Alot There Heavy
electrical1 is offline
noyzee
Baja
4
08-19-2008 12:04 PM
tomswift
18
04-20-2007 09:09 PM
epeek
9
10-25-2004 05:33 PM
epeek
Fountain
10
10-24-2004 08:45 PM
imq707s
17
06-30-2002 09:07 PM
