496 ho seawater punp impeller??? >
Old 05-30-2004 | 01:32 PM
Question 496 ho seawater punp impeller???
I'm replacing a sea water pump impeller.
The impeller blades need to be folded to fit, do I bend them clockwise or anti-clockwise,
regards
Rick
docricky is offline
Old 05-31-2004 | 08:22 AM
Default Re: 496 ho seawater punp impeller???
I put some white grease on mine and put them in. It does not matter how you put them in, because when you start the boat they will align themselves.
I have never had a problem with mine.
If you are going to be very particular, then put them in to turn the way the housing arrow shows. The arrow is on the front of the housing.
Steet is offline
Old 05-31-2004 | 12:55 PM
Just make sure you have them turning the correct way....
Vyper340 is offline
Old 06-01-2004 | 01:03 AM
Strip Poker 388's Avatar
Rob
I use soap to lube them so they will slide in. they usually turn clock wise if your looking at it from the back . try to get the blades going in the right direction to start out with I use needle nose plyers to get it in.. its usually a dry start up until the water starts flowing.
Change the housing also.merc makes a kit now
Rob
Strip Poker 388 is offline
Old 06-01-2004 | 08:43 AM
rv
Strip Poker,
Merc makes a housing kit now for the 496HO???
Do you have a part number.
Thanks,
Rick
rv is offline
Old 06-01-2004 | 06:12 PM
Pwrbt33's Avatar
Talking Re: 496 ho seawater punp impeller???
When i you install the impeller make sure you turn it counter clockwise when you push it in this way they will be aligned. Like everyone else said use grease or soap or something to help lube until it picks up water. You will se some grooves down inside but it seems all the 496's have that.
Pwrbt33
Offshore Performance
1-877-GOFAST1
Pwrbt33 is offline
Old 06-01-2004 | 11:25 PM
Rob
Originally Posted by rv
Strip Poker,
Thanks,
Rick
Not shure on the 496 . Try some of the sponsors in the link list on here.You should beable to find the # there.
Rob
Old 06-02-2004 | 01:54 PM
Thanks guys, got it in and working.
Rick
docricky is offline
apexer
3
05-07-2008 07:17 AM
turnerrd
1
08-17-2006 09:38 PM
Bolts21
8
05-15-2006 09:49 AM
davis777
16
02-04-2006 09:19 PM
BajaBoss252
12
11-16-2003 03:34 PM
