No Oil Coolers Good Or Bad >
Old 05-31-2004 | 12:41 AM
Default No Oil Coolers Good Or Bad
42 Fountain 3 525sc Plan To Run No Oil Cooler's And No Thermostats ?all 3 Motors Ran At 140 Degrees Last Year With Thermostats And Oil Coolers. Do You Guys Think The Oil Will Get To Hot???the Reason For This Is Oil Lines And Hoses Were Leaking Very Bad Do Not Want To Blow A Motor!!!!!!
42FOUNTAIN is offline
Old 05-31-2004 | 03:14 AM
Default Re: No Oil Coolers Good Or Bad
You don't want to blow an engine, but you're removing the oil coolers???
You need both the t-stats and oil coolers to keep temps constant and keep them reliable.
Griff is offline
Old 05-31-2004 | 09:18 AM
obnoxus's Avatar
Charter Member #1171
PREPARE FOR A MELTDOWN !!!!!!!! In other words,,, fix the leak.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 05-31-2004 | 10:21 AM
cuda's Avatar
You need oil coolers. The reason they aren't needed in a car application is the oil pan in a car is always exposed to the air rushing under it and cooling the engines. Oil cooling lines are much cheaper than crankshafts, bearings, rods etc.
Talk about an oil leak, here's what I had after one day of running in a poker run. Took it in to the mechanic at noon one day and had it back by noon the next day. Total cost $347.
cuda is offline
Old 05-31-2004 | 07:10 PM
MACDAD260's Avatar
Charter Member #818
Don't even think about running without oil coolers! Engines that are under constant load like a boat engine need oil coolers. Even most light trucks that have factory installed towing packages have oil coolers. That's what the little radiator in front of the main radiator is. Some trucks have two of those things. One is for the engine and the second is for the transmission. The big rigs all have them. They are usually built into the engine and use coolant to keep the oil temp down.Have you ever seen the radiator on a semi? They're huge. Since a boat has no way to use air to cool anything in the engine compartment they also use water to cool things. The difference is that sea (or lake) water is used to carry the heat away.
Bite the bullet and get those lines replaced or it will get a lot more expensive. Good luck.
MACDAD260 is offline
Old 05-31-2004 | 09:34 PM
mopower's Avatar
Toxic FORMULA
All the above! Don't even think about no oil cooler ESPECIALLY with a SC engine.
mopower is offline
Old 06-01-2004 | 02:07 PM
SSComp's Avatar
I just replaced my OEM coolers with Revolution Marine's. Big honkin coolers realistically priced.
Are you running oil temp gauges, if so what were your oil temps last year?
By the way..DO NOT RUN BLOWER MOTORS W/O OIL COOLERS.
SSComp is offline
cougarman
6
07-25-2007 11:03 AM
Back4More
10-14-2006 08:36 AM
dean51267
14
08-05-2006 12:07 AM
johnnyboatman
15
02-23-2006 01:21 AM
Shah Mat
13
11-30-2003 08:46 PM
