Shift/Throttle cable compatibility >
Old 06-16-2004 | 08:26 AM
Kokopelli's Avatar
Default Shift/Throttle cable compatibility
A friend is wanting to convert his single arm Commander 3000 throttle/shifter to a merc. zero effort separate throttle and shifter set up. Does anyone know if he will have to swap out cables or are his current ones compatible?
Kokopelli is offline
Old 06-16-2004 | 08:59 AM
DanB's Avatar
Charter Member #71
Default Re: Shift/Throttle cable compatibility
If I'm not mistaken, pretty much all cables are standard, the only thing different are the ends, and they screw on and off, so he would need an end for the zero effort, which I belive is a hook kind of deal that screws on to the end of the cable. They should come with the shifter if he is buying new.
Dan
DanB is offline
Old 06-16-2004 | 10:26 AM
38KV's Avatar
The zero effort control require Morse 33c style cables. (First pic)
If the current cables looks like the second pic, you need the adpter kit in pic three.
Attached Thumbnails Shift/Throttle cable compatibility-ufx-c5.jpg   Shift/Throttle cable compatibility-4601-0120.jpg
38KV is offline
Old 10-11-2006 | 06:37 PM
Dtile's Avatar
hello..Im trying to do the same but I dont see how my non 33c cable that i have will fit with the adapter pictured. i purchased a used keikekiefer zero effort and taking apart for powder. should I just take my old cable off, measure and buy the new 33c (Telflex TFXtreme Cable)...will i still need an adapter?
any help appreciated.
Dtile is offline
Old 10-11-2006 | 08:26 PM
Mbam's Avatar
Offshoreonly Advertiser
Dtile, you are correct. Must use 33C style. 38KV, the adapter pictured is to convert a 33C to Merc style at the engine end.
Mbam is offline
Old 10-11-2006 | 08:44 PM
Dtile's Avatar
ok, so ill need from you (bam website i assume) two clevis control cable ends (part # 845281), and 2 cable adapter kits (from trick?)
and two new cables..
http://www.mercruiserparts.com/Show_...PAGE+2+OF+2%29
What about securing the new cable to the bracket (my bracket on has one leg)...
thanks for the replay, will be calling you when i know what i need....
Dtile is offline
Old 10-12-2006 | 06:16 AM
Mbam's Avatar
Actualy there is a Merc part number for the adapters too, I'll try and remember to post it later.
Mbam is offline
Old 10-12-2006 | 12:50 PM
Dtile's Avatar
ok i ordered the clevis (2) online, I called but you dont take orders over the phone for some reason... thanks.
Dtile is offline
Old 08-10-2012 | 11:15 AM
phughes69's Avatar
Marc, did you ever find the part number for those adapters?
I removed my old Morse throttle and am going to install the Zero Effort controls. I believe my cables are the 600A cables.
Patrick
phughes69 is offline
Old 08-10-2012 | 11:41 AM
Mbam's Avatar
Patrcik, I am not sure what a 600A is. Can you post a picture?
Mbam is offline
