Livorsi Tach Problem >
Old 06-21-2004 | 03:58 PM
Ran-Dom 32's Avatar
Default Livorsi Tach Problem
I have twin 502 MPI & recently put two new Livorsi tachs. They read almost identical up to 4000 rpm after that the port tach flutters & bounces between 4000 - 4500 & the SB reads fine . Engines seem to run fine no miss what-so-ever. I swapped the two tachs the other day to see if I had a bad tach but same problem. any ideas?? bad ground ? I checked seems fine any ideas?? thanks,
Ran-Dom 32 is offline
Old 06-21-2004 | 04:43 PM
Ed
Default Re: Livorsi Tach Problem
Bad Tach...Simply call up Mike Livorsi and have it replaced under warranty. Peace of cake. Ed
Ed is offline
Old 06-21-2004 | 07:34 PM
Ran-Dom 32's Avatar
I swapped the SB tach for the Port, does the same thing - SB side has a problem somewhere??
Old 06-22-2004 | 01:42 PM
Ran-Dom 32's Avatar
ttt everyone must be out boating??
JLAY
0
06-20-2007 08:44 AM
pokerrunboats
04-11-2007 01:32 PM
wrenchman
5
06-03-2005 10:50 PM
carter38
1
09-01-2004 11:01 PM
