Hydromotive QIV Vs Bravo 1    Q"s >
Old 06-23-2004 | 12:14 AM
Rookie's Avatar
Default Hydromotive QIV Vs Bravo 1 Q"s
Just curious about the performance difference between these two props. I have a set of Hydro QIV 25's and a set of Quicksilver 25's. I noticed the 3 blades raise the bow higher, harder to get on plane, is a little looser, and a lot faster. The QIV's lift the stern, quick planing, feels that it is plowing water, tighter turning a little more in control feel, and alot slower.
Would it be worth it to try a set of Bravo 1's, or would they be very comparable to the QIV's.
Rookie is offline
Old 06-23-2004 | 06:28 AM
Default Re: Hydromotive QIV Vs Bravo 1 Q"s
I just tried out a QIV and QIV-X on my single engine application after having run a stock bravo one. The QIV was a full 5 mph slower than the Bravo, and I experienced all the same ride characteristics that you've described - the boat was glued to the water. Went with the QIV-X on the rec. of Hydromotive. It is much more of a bow-lifting prop. Worked better, but still 2 mph slower at all rpms than the Bravo One. On top of that, I don't think the hydros are great candidates for labbing, since the blades are already pretty thin. So, when I take the Bravo and get it labbed, I'll end up a good 3-4 mph faster than the QIV-X. That said, the QIV-X might be worth a try, a fellow boater with a the same make of boat, only longer and heavier, picked up 2 mph over the Bravo One. You never want to leave the speed on the table so you might as well try it. Good luck.
bouncedcheque is offline
Old 06-23-2004 | 09:16 AM
dlbCheckmate's Avatar
Check your RPM's also when compairing the two. It has been my experiance that they do not measure pitch the same. Generally I go up in pitch when using Bravo's vs. Hydro's. Just my 2 cents....
dlbCheckmate is offline
Old 06-23-2004 | 02:12 PM
Rookie's Avatar
My experience with the Hydro's versus the quicksilvers was a loss of 7 mph.
Rookie is offline
Old 06-23-2004 | 03:05 PM
throttleup's Avatar
dblcheckmate,
You are absolutely right on the differences in pitch. The Bravo I are 1 inch less in pitch. Not all boats do well with the sternlifting propellers in which the Bravo I and Hydromotive X props work better as bow lifting propellers.
Julie
throttleup is offline
Old 06-20-2007 | 12:58 PM
onesickpantera's Avatar
Rookie, Bravos will be better than the QIV but you may want to try a set of Rev4s. It has better bow lift than the Bravo 1 and ran looser and faster on my boat. By far the best 4 blade I have tried.
onesickpantera is offline
tony stamis
Swap Shop
2
07-14-2008 09:12 PM
Fast Forward
Prop Talk
7
07-11-2008 09:08 PM
Toffen
Prop Talk
3
01-03-2008 08:25 PM
tekfal23
Prop Talk
6
06-12-2006 12:56 PM
CN24
Prop Talk
4
04-24-2006 06:12 PM
