502 mpi supercharger headgaskets >
Old 06-29-2004 | 06:38 PM
blownboat
Default 502 mpi supercharger headgaskets
I have read alot of threads. Any suggestions on what gasket. 7lbs of boost. A part number would be great. Thanks
Old 06-29-2004 | 09:08 PM
Vinny P's Avatar
I hate the winter!!
Default Re: 502 mpi supercharger headgaskets
I don't have any first hand experience with this. But, many on this board swear by cometic gaskets..
http://www.cometic.com/
Vinny P is offline
Old 06-29-2004 | 09:09 PM
Cometic is what you want, don't have a part number but do a search on Cometic to help you with selection.
BadDog is offline
Old 06-29-2004 | 09:45 PM
Smitty's Avatar
I run Fel-Pro marine gskts. 3 seasons of 6 lbs boost no problems.
Smitty is offline
Old 06-29-2004 | 11:08 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Fel-Pro here also. 6 yrs @ 5lbs, trouble free
US1 Fountain is offline
Old 06-30-2004 | 08:31 AM
28Eliminator's Avatar
FelPro marine 1047 is what I use. 6lbs
The Cometics are good also, but the felpro is easily available for me and works just fine. In fact, I'm going to pickup a set today, since I had a problem with over heating due to sucking up sand. I had a valve job done and all should be good.
28Eliminator is offline
Old 06-30-2004 | 11:34 AM
blownboat
Thanks for all you opinions.
Old 07-01-2004 | 08:28 AM
Whatever gasket you run after initial start bring engine up to temp then let engine cool and retorque the h/gaskets. Even though you not supposed to have to do this it makes a difference. Been there done that!
kennyo is offline
cass236
2
07-21-2008 01:00 PM
brian valery
05-17-2007 04:40 PM
tomcat
106
10-14-2004 10:52 AM
Steve_H
11
02-07-2004 05:57 PM
JEFF L
11
11-09-2002 09:44 AM
