How much"milk shake"if any, acceptable??? >
Old 07-25-2004 | 09:14 PM
Default How much"milk shake"if any, acceptable???
Got some cream in my valve area.dipstick looks good. Am I not getting hot enough or do I need a vent to carb to pull moisture out or am I leaking somewhere. My gauge shows 220 deg but only when WOT. Any tricks?Any chems to help?,,,,,,,,,,,,,,Must be my new intake
cooltoys61 is offline
Old 07-26-2004 | 04:06 AM
cig1988's Avatar
Default Re: How much"milk shake"if any, acceptable???
Drain the oil or remove the oil filter. If you installed a new intake that may be the problem. The cork you are supposed to use sometimes raises the intake manifold too high and the bottom of the manifold will not seal. A tell tail would be a vacuum leak. If this is the problem, use hi temp silicon on both sides on all 4 water ports. Prior to that, place the manifold on the engine to determine how much of a bead to run in place of the cork. Good luck, Stan.
cig1988 is offline
Old 07-26-2004 | 05:55 AM
NONE!
Pure Energy is offline
Old 07-26-2004 | 12:33 PM
I used silicon(no cork) the first time and fel-pro with some silicone around the jackets and the threads. When washing I may have gotten a few drops into the vents . Would that be enough to cream up the valve area??
Old 07-26-2004 | 05:35 PM
If you run oil thermostats, your oil temp will be 215-220 without top RPM to build heat. Constant 212+ oil temp is the best way to manage water from condensation. The moisture will boil and vent out.
BenPerfected is offline
bobo1
OPA/The Jersey Boyz
0
04-23-2008 07:36 PM
electrical1
11
11-09-2006 08:51 AM
Ben@SRP
14
10-13-2006 09:11 AM
mikesufka
12-26-2002 11:23 AM
syringa
14
07-01-2002 06:27 PM
