Engine allignment help! >
Old 07-30-2004 | 09:08 AM
fo-shizzle's Avatar
Default Engine allignment help!
Rebuilt a 383 small block (330hp) in a Formula 242LS with an Alpha outdrive. Put engine back in last night and not sure if alligned properly to gimbal housing. Inserted the Mercruiser allignment tool with a light push. The tool spins but has some resistance.....
Question is: How much spinning resistance is too much? I know it is hard to quantify effort, but shoud rotate easilly with just thumb and fore-finger or free-spin?
any insight appreciated!
fo-shizzle is offline
Old 07-30-2004 | 09:12 AM
fund razor's Avatar
Default Re: Engine allignment help!
They say that it should move easy.
Slide right in and out with a couple fingers and minimum effort.
Sounds like you might be close.
fund razor is offline
Old 07-30-2004 | 09:57 AM
JON242
I wouldn't worry about how it spins. Just straight in and out without having to force it. Put some lithium grease on the last few inches of the tool and read the spline grooves in the grease after you pull it out. They should be the same on top and bottom.
Old 07-30-2004 | 10:14 AM
Official OSO boat whore
Hold the tool between two fingers. When it slides in and out like that, you are aligned.
Cord is offline
Old 07-30-2004 | 10:19 AM
take a look at the gimbal bearing...it may need replacing as well(and or) aligned.
audacity is offline
Old 07-30-2004 | 10:23 AM
fo-shizzle's Avatar
Wink Re: Engine allignment help!
Sliding the tool in and out with two fingers sounds like what i was thinking... Checking the grease amount around the shaft should help me get an idea of what direction it needs to be adjusted...
Yesterday, the tool would slightly hit and make a little "clunk" noise and then would slide in with a little pressure... Sounds like I need to do a little adjusting tonight...
Thanks for the feedback!
First boat and quite the learning experience, but should help when I step into a boat with twins......
THRILLSEEKER
11
07-04-2012 11:39 PM
31scarab31
Drives and Lower Units
11
03-07-2008 12:59 PM
markt111
1
08-12-2004 10:25 AM
THRILLSEEKER
3
06-15-2003 06:32 AM
Cord
03-28-2002 11:08 PM
