supercharged 525s >
supercharged 525s
supercharged 525s
Old 08-15-2004 | 10:27 AM
hugeld
Default supercharged 525s
I am thinking of purchasing a 38 fountain w/mercruiser 525 scs they have 199 hrs on them I know nothing about supercharged motors.What maintenence do they require and when.I heard you should do a valve job at 200 hrs?
Old 08-15-2004 | 10:58 AM
Default Re: supercharged 525s
These are 454 motors with a small charger on them. I think they are the 250 range such as a B&M. A valve job would be a must. Becuause you don't probably know the full history of those motors. Overheated, Gas choices, How often serviced, etc. The last thing you want to do is drop a valve seat. You need to do a compression check and cylinder leak down test. I would be willing to bet there is some leakage past some of your exhaust valves.
PowerboatsNW is offline
Old 08-15-2004 | 06:18 PM
hugeld
thanks,anything else you'ld recommend
Old 08-16-2004 | 01:14 AM
I've got a single 525sc in my Pantera. I just freshened the top half of the engine at 330hrs and added a roller cam. Everything was in better shape than I would have thought. I needed to have a valve job done due to some water getting into one of the cylinders and it pitted the valve.
I change the oil every 25-30 hours and run synthetic. The only other maintance other than a normal engine is to change the blower lube every 50 hrs or so. I also check the level every 10 or so hours.
The engine is completely turn key and reliable.
Griff is offline
Old 08-16-2004 | 01:15 AM
puder's Avatar
speel chekk this fokker!
i've heard the 52sc reffered to as the "best merc blue engine produced" so it seem to be pretty well liked. Good power, good reliabilty. i believe the supercharged used on it was the wiend 177.
as for checking out same checks that you'd do on a non blower motor. YOu might wnat to measure the boost pulley and see what size it is so you can figure dout how much boost they were running.
Pardon me, while I whip this out!
puder is offline
Also, due a search for 525SC and you will find a ton of info on them.
Griff is offline
Old 08-16-2004 | 09:15 PM
iamfaster's Avatar
Hey Griff, did the Roller cam make a difference? Did you see an increase in R's after the rebuild. Which cam and why did you select it. I will probably freshen my 525's over the winter. Any other suggestions other then intercoolers and smaller pulleys for little more HP?
iamfaster is offline
Quinlan
11
10-19-2008 05:12 PM
DRIVEN1
Fountain
3
06-11-2006 08:11 PM
JC
Cigarette
5
04-30-2004 08:59 PM
JC
04-20-2004 06:20 AM
JC
04-19-2004 06:38 AM
