Trim Question????? >
Trim Question?????
Trim Question?????
Old 08-19-2004 | 03:21 AM
tomtbone1993's Avatar
Default Trim Question?????
Bravo outdrive, goes up or down then stops after a second. wait about 10 seconds, hit the button. Does the same thing works for one or two seconds then stops.
tomtbone1993 is offline
Old 08-19-2004 | 07:11 AM
Default Re: Trim Question?????
the motor has an overheat swich built into it,if the motor is dragging or the pump itself is putting to much load on the motor then the swich will open until it cools down,also low voltage corroded connections can also cause problems,low current with excessive amp draw will also cause overheatig.
proboat-wes is offline
Dave98
Powerquest
6
04-27-2005 11:31 AM
Phantom1
1
04-12-2005 02:13 PM
cooltoys61
11
08-02-2004 08:27 PM
later
6
07-01-2003 08:31 AM
mcorcora
2
06-12-2002 07:15 PM
