Recomended way to remove props on Speedmaster's? >
Old 08-22-2004 | 01:38 AM
phughes69's Avatar
Default Recomended way to remove props on Speedmaster's?
What is the recommended way to remove the props on speedmaster drives? What is the easiest way?
phughes69 is offline
Old 08-22-2004 | 05:47 AM
Pwrbt33's Avatar
Default Re: Recomended way to remove props on Speedmaster's?
Usually you can take a hard block of wood and a good heavy hammer and hit the side if the hub. Put the wood flat along the bottom of the blade where it attatches to the hub and hit it. Make sure you thread the nut on a few threads when you do this, they sometimes pop and slide off the prop shaft. If that doesnt work and its really stuck on there, you can try a brass drift or punch and hit the back side of the hub and try to break it loose as well.
Pwrbt33
Offshore Performance
410-827-0200
1-877-GOFAST1
Pwrbt33 is offline
Old 08-22-2004 | 06:40 AM
I use a length of 4x4 wood between the prop and anti-cavitation plate to break the prop nut loose. I use anti-seize on the splines and have had no problem getting them off. Torque for the prop nut on the #5's is 100 ft lbs according to the manual. There was a thread on this topic a month or two ago. For what it's worth.
Lmarth is offline
Old 08-22-2004 | 11:42 AM
phughes69's Avatar
I used a board between the blade and the cavitation plate to get the prop nut loose and then put a block of wood against the base of the blades and gave it a good wack with a hammer and off it poped. Thanks guys.
Old 08-22-2004 | 12:29 PM
Comanche3Six's Avatar
Grab the blade with both hands, have a friend remove the prop nut. Carefully strike the prop hub with a heavy duty plastic hammer. Remove the prop.
Comanche3Six is offline
niceguy
03-30-2008 09:34 PM
fabtech04
3
06-05-2007 06:58 PM
blade88
Prop Talk
0
08-30-2006 10:52 AM
Von Bongo
Cigarette
4
06-23-2004 02:17 PM
Tom
02-20-2003 04:46 AM
