Sonic Cavitation >
Sonic Cavitation
Sonic Cavitation
Old 08-25-2004 | 10:32 AM
Penaltybox's Avatar
Default Sonic Cavitation
I have a 28' Sonic. The boat has twin 502's. The props are 3-blade 25P, Mirage's. The boat has a BAD cavitation problem, when coming out of the hole, at more than half throttle, AND in rough water. Any suggestions???
Penaltybox is offline
Old 08-25-2004 | 10:50 AM
throttleup's Avatar
Default Re: Sonic Cavitation
Try a 4 blade prop this should eliminate the problem.
Julie
throttleup is offline
Old 08-25-2004 | 11:07 AM
dyno's Avatar
Charter Member #655
Julie
Got that right!!
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 08-25-2004 | 11:10 AM
Official OSO boat whore
The bravo 1 will solve the problems that you are describing.
Cord is offline
Old 08-25-2004 | 01:52 PM
Ttt
BobbyB is offline
Old 08-25-2004 | 04:57 PM
Are you running drive showers by chance? The Simrek can cause cavitation if the tube extends through the anti cav plate too much.
BadDog is offline
Old 08-25-2004 | 05:22 PM
Dave M's Avatar
Veteran: Navy
I had the same problem with Mirage+'s on my boat. My prop would break loose and I would have to come off plane to get it to hook up again. I Switched to a Bravo 1 and the issue went away.
Dave M is offline
Old 08-25-2004 | 06:05 PM
throttleup's Avatar
Are the props Mirage's or Mirage Plus'?
What year is your boat?
Typically if your boat is difficult or impossible to get on plane with three blade props it's time to go to 4 blade props. Typically the overall performance of the boat will greatly improve with the 4 blade props
Matt
Old 08-25-2004 | 06:42 PM
articfriends's Avatar
Did it always do this since you've had it or is it something new? Are you running solid hubs? I had a 23 pitch 3 blade on my baot w/single stock power and it would slip a little out of hole but was fine the rest of the time,i put 50% mor power to it,tried a 27 pitch 3 blade,was super hard to get on plane and slipped almost identical to what your describing,solved problem w/4 blade.
articfriends is offline
Boater0979
Drives and Lower Units
8
08-11-2008 07:08 PM
walkintheplank
Prop Talk
1
09-11-2006 09:12 PM
JON242
1
09-09-2004 04:21 PM
rlavigne
03-15-2004 06:42 AM
SSComp
9
05-11-2003 02:13 PM
