changing throttle/shifter controls >
Old 08-26-2004 | 01:25 AM
HiPerf2000's Avatar
Default changing throttle/shifter controls
Friend is looking to change out his older style single (all in one) control to the zero effort separate shifter/throttle controls. this is a single motor setup. Will the cables need to replaced or just the ends? Also, does anyone have a used setup for sale??
HiPerf2000 is offline
Old 08-26-2004 | 06:40 AM
cuda's Avatar
Default Re: changing throttle/shifter controls
Just the ends. I'm doing the same thing.
cuda is offline
Old 08-26-2004 | 07:04 AM
HiPerf2000's Avatar
Cuda, what shifter did you buy and where did you get it?
Old 08-26-2004 | 07:17 AM
cuda's Avatar
Gaffrig and I got it from poffshore
Attached Thumbnails changing throttle/shifter controls-gaffrig-002.jpg
cuda is offline
Old 08-26-2004 | 07:24 AM
Ted G's Avatar
Some cables have ends that are not removable, so he will need new cables too. And if you are doing the job, a new set of cables is a good idea anyway. Use the Teleflex TFXtremes-they make a world of difference in how the controls work.
www.cbpba.com
Ted G is offline
Old 08-26-2004 | 08:44 PM
Formula78's Avatar
I did the same swap on my single engine Formula. I used the Mercury Zero Effort controls and TeleFlex Extreme cables. They worked great.
Formula78 is offline
the vig
2
10-13-2008 11:15 AM
JohnnyG
Drives and Lower Units
1
09-08-2007 10:33 AM
aero-offshore
2
06-21-2004 03:14 PM
masi242
12-08-2002 10:36 AM
rwilson
6
05-08-2002 08:44 AM
