Bravo XR's?
Old 08-27-2004 | 06:59 AM
Default Bravo XR's?
How much hp are theese things rated for?
How would they hold up on a heavy boat (10k ish) with say 5 to 750 hp. in rough water conditions?
Also do they bolt up to a Bravo 1 gimbal?
THRILLSEEKER is offline
Old 08-27-2004 | 09:06 AM
Doller Offshore
Default Re: Bravo XR's?
the bravo 1 xr is rated for 575hp,that is the biggest motor merc puts on them,some people put more but it depends on application.yes they do bolt up on bravo gimbals but you have to change the gimbal bearing because of the larger u-joint of the xr
art
Old 08-27-2004 | 10:26 AM
And add the trim limiters in the rams lest you bind the u-joint. The seal behind the gimbal bearing may be off different size as well.
BadDog is offline
Old 08-27-2004 | 10:53 AM
GLH's Avatar
GLH
Just re-torque the topcap of the left turning prop every so often. Running about 650 HP's pushing #10k.
Ask airpacker how the drives held up in the rough day he was on the rig!!!! I am carefull out of the hole also.
GLH is offline
Old 08-28-2004 | 07:01 AM
Biggus's Avatar
Put on a pair of Konrad's
and you won't have to be careful
Biggus is offline
Nauti By Nature
Drives and Lower Units
99
04-28-2008 09:09 AM
bryanh
Super Boat International
0
10-03-2006 05:31 PM
bryanh
General Racing Discussion
0
10-03-2006 05:30 PM
Doller Offshore
New Products and Member Discounts
4
08-11-2006 01:14 PM
CAFE
Fountain
13
06-13-2004 10:59 PM
