MerCruiser Rev Limiter? >
Old 09-06-2004 | 10:06 PM
gnimelf4
Question MerCruiser Rev Limiter?
Is there a way to bypass the factory rev limiter on a 98 mercruiser 5.7, up to and including a new ignition box. If it requires a aftermarket box which would you use?
Old 09-07-2004 | 08:09 AM
Talking Re: MerCruiser Rev Limiter?
Well here I go again. I usually get spanked when I answer this but I changed over to MSD complete system for the same reason. There are other threads that cover the MANY choices for this. GOOD LUCK. I'm going to set back and wait for the MSD bombs to hit this thread.
Badtoon is offline
Old 11-23-2006 | 02:12 PM
Default Re: MerCruiser Rev Limiter?
Help My mercruiser 454 apache eagle 24 revlimiter cuts in at 5000 rpm and feels like this is killing my top speed how do I bypass or modify this thing for a higher rpm??
Apacheagle24 is offline
Old 11-23-2006 | 04:23 PM
axapowell's Avatar
Where To
I use the Crane Hi-6m. Works great, has timing curve and limiter built right in. Either Crane or MSD. Your choice!
Dave
axapowell is offline
Old 11-24-2006 | 03:16 PM
There is no reason to change the rev limiter on a stock 5.7
It is making the most power/torque at the top of the recommended WOT range. After that, torque falls off a lot.
The best thing to do is prop the boat to run just short of hitting the limiter.
Griff is offline
Old 11-24-2006 | 03:18 PM
The best solution is to get a bigger prop or have yours reworked.
Griff is offline
Old 11-24-2006 | 05:37 PM
Strip Poker 388's Avatar
Rob
I run MSD on all my stuff. Some people have bad luck with them,Ive never had a prob.The box on my old Scarab is still running from 1992
Strip Poker 388 is offline
mcprodesign
Fountain
4
05-19-2008 06:37 PM
D Harry
0
06-23-2007 04:26 AM
wd833
0
04-01-2004 06:16 AM
Vinny P
4
05-14-2003 09:01 PM
THRILLSEEKER
6
07-25-2002 07:30 AM
