How Long at W.F.O. ??
Old 09-10-2004 | 03:31 PM
Strip Poker 388's Avatar
Rob
Default How Long at W.F.O. ??
How long have you held your boat engine at WFO not letting out of it?Balls to the wall in flat water
How many minutes??
On my 500efi's I have for about 10 minutes and the water and oil temps where all good .
Just think about the offshore races that are flat and they never let out of it
Strip Poker 388 is offline
Old 09-10-2004 | 03:36 PM
Havasu Cig's Avatar
Default Re: How Long at W.F.O. ??
100 miles two weeks ago at the Scope run. About 1 hour and 15 minutes broken up by 4 card stops.
BTW they are 500 efi's.
Havasu Cig is offline
Old 09-10-2004 | 03:39 PM
FunHome's Avatar
Usually for about a hour, back when we raced!! 500hp carb.
It took a while for the oil temp. to get up there, never a problem!! after the race when the oil was hot the oil pressure would be down about 10lbs at idle.
FunHome is offline
Old 09-10-2004 | 03:40 PM
Havasu Cig's Avatar
My oil pressure and temps were all good after the run. 10 pounds seems really low!!
Old 09-10-2004 | 03:47 PM
BajaRunner's Avatar
I know what it is but what the hell does WFO stand for? I always thought it was WOT Wide open throttle?
BajaRunner is offline
Old 09-10-2004 | 03:48 PM
BajaRunner's Avatar
better have a drive shower too
FeverFan's Avatar
Wide F*cking Open?
FeverFan is offline
Old 09-10-2004 | 06:16 PM
GO4BROKE's Avatar
Until it breaks or I win.
[img][/img]
GO4BROKE is offline
Old 09-10-2004 | 06:41 PM
Have held the "Pull My Trigger" smallblocks wide open down a BIG lake up here for 25-30min once, just pinned it and left it there. oil temp was up to about 240 and about 10-15 lbs oil press at idle...milled around for a few minutes after and got the oil temp down to around 180 before I shut it down......told a bunch of car guy friends of mine that I did this and they couldnt beleve it..........done it lots of times for 10 or 15.........
pullmytrigger is offline
Old 09-10-2004 | 07:11 PM
HyperBaja's Avatar
Continuous? Roughly 3 hours.
Overall...... Carb motor with no computer, since we have owned it I would say majority of the hours (90%) are wfo, 5200 (need a bigger prop, 4600 is where she needs to be)
HyperBaja is offline
