Resleeve Merc Pro Max outboard >
Old 09-16-2004 | 02:00 PM
Registered User
Default Resleeve Merc Pro Max outboard
Does anyone know a good source for resleeving HP outboard motors in the Detroit or Michigan area?
Slow Ride is offline
Old 09-16-2004 | 02:41 PM
boatn70's Avatar
Default Re: Resleeve Merc Pro Max outboard
go to www.screamandfly.com for the most info on outboards, great forums!!
boatn70 is offline
Old 09-16-2004 | 07:27 PM
mcollinstn's Avatar
We got a local guy around here. You probably do, too, if you ask around at the motorcycle shops.
If you sleeve to cast iron, you gotta run different rings.
mcollinstn is offline
Old 09-16-2004 | 09:44 PM
Audiofn's Avatar
Charter Member #232
guys that really know what they are doing can still sleeve the original nickle plated cylinders. I think that they hone it differently then a cast sleeve. From what I hear you loose HP with the cast sleeves.
Jon
Put your best foot forward!
Audiofn is offline
Old 09-16-2004 | 10:21 PM
mcollinstn's Avatar
If you run an old Bridgeport block, the iron liners are actually necessary if you run nitrous. Otherwise the bridge melts out.
I've had blocks with two iron sleeves, and 4 Nikasil holes. They run just fine that way. Whole lot cheaper than a new block. Course if you just got some light scratches, you can overbore and re-Nikasil pretty affordably.
teamsutphen
05-17-2020 12:33 AM
SLINGSHOT
11-16-2014 04:01 AM
Hollywood300
Spectre
5
08-22-2007 05:23 PM
Wettin My Shorts
2
01-16-2006 05:54 PM
frequentflyer
5
10-28-2002 07:51 AM
