prop question >
prop question
prop question
Old 09-19-2004 | 04:54 PM
johnnyboatman's Avatar
Default prop question
31 warlock cat, 2 509s w/ 250 blowers , 136 gear ratio, ran 97.9 on gps. problem is when trying two get more speed it hops frt to back like a buck board scarry. not as bad loaded with people but when trying to get all the speed . it has a 29 hydro w/diffuser ring. thinking of trying some bravos 30 or 32s
johnnyboatman is offline
Old 09-20-2004 | 07:47 PM
Default Re: prop question
help
Old 09-20-2004 | 11:10 PM
T-N-T Sales
Try a rotation change. It is the first thing I would try as you can do it with your existing hardware. It will change your stern lift. # of blades will also change lift. There are many other things to try if this doesn't help. It may give you an idea what the boat needs.
Old 09-20-2004 | 11:48 PM
HOUSTONPROP's Avatar
I would try the rotation game and also possibly reduce some of the cupping as it's trying to lift the bow and dropping down.You may need to bump the pitch up a 1" if you do this .Darin
HOUSTONPROP is offline
Old 09-21-2004 | 12:11 AM
bimmerboy318
Prop Talk
7
07-12-2008 09:46 AM
fountain 47 sc
Drives and Lower Units
1
03-09-2008 07:57 PM
Sea-Dated
Prop Talk
15
06-02-2006 04:49 PM
Excalibur502mag
0
08-12-2004 12:40 AM
FlyFast
1
08-06-2004 10:22 AM
