Audio ,video guys HELP ! Did I get screwed ? >
Old 09-23-2004 | 08:21 AM
Default Audio ,video guys HELP ! Did I get screwed ?
I just got this for $26 ....
It is a sharp , LCD monitor .
The discription says " Sharp 5.7 Inch TFT color panel for IA application" .
WHat is "IA" ?
I want to use this for DVD & GPS. Will it work ? WHats up with this funky plug ? It is 2 wires ,flat plastic plug . red and white wires. Can I make it an RCA jack or what ever they call them, so I can plug it into my radio ?
HELP !!! Thanks , Joe
Attached Thumbnails Audio ,video guys HELP ! Did I get screwed ?-hpim0439.jpg   Audio ,video guys HELP ! Did I get screwed ?-hpim0437.jpg
boot is offline
Old 09-23-2004 | 08:50 AM
CigDaze's Avatar
Default Re: Audio ,video guys HELP ! Did I get screwed ?
Red and white, looks like DC power...are there any other connections?
CigDaze is offline
Old 09-23-2004 | 09:10 AM
wwwTOPDJcom's Avatar
does the white wire have a shield and center conductor?
if so I would say red is hot and the sheild is ground, center conductor on the white if it has one will be standard video in
wwwTOPDJcom is offline
Old 09-23-2004 | 09:38 PM
mcollinstn's Avatar
Looks like a "refill" for a monitor. As in "just the screen" without the electronics. My guess is that the two wire connector is for the backlight.
If I'm right, it will have a provision on it somewhere for a ribbon cable about 1.5" wide that goes from the screen unit to the electronic driver hardware.
Hope I'm wrong.
mcollinstn is offline
Old 09-23-2004 | 09:49 PM
fund razor's Avatar
Hope I'm wrong.
That was my guess. Looked proprietary to some installed system with component electronics. Not universal at all.
fund razor is offline
Old 09-28-2004 | 08:26 AM
mcollinstn's Avatar
You've still got the same question on OFFTOPIC.
I still say it is a DISPLAY only, without the "GUTS" you need to make it work.
And you can't just find GUTS unless you manage to locate a complete monitor with a broken panel of the same pixel resolution. Not impossible, but kind of like that needle haystack thing...
ferraristyle
08-23-2005 02:19 PM
mr_velocity
03-11-2005 12:30 PM
Elite Marine
6
11-27-2004 12:10 AM
boot
10-01-2004 12:55 PM
