Winterize 500 efi >
Winterize 500 efi
Winterize 500 efi
Old 11-08-2004 | 10:00 AM
CRD
Default Winterize 500 efi
If anyone knows how many water drain plugs there are on each side of the block, would appreciate the input. In process of winterizing and would to ensure all the water is drained...
Thank you
Old 11-08-2004 | 10:06 AM
marinetrans's Avatar
Default Re: Winterize 500 efi
One on each side of block, one on each end of headers (5/16 allen),one on cool fuel system.
marinetrans is offline
Old 11-08-2004 | 10:54 AM
CRD
Thanks for your reply, I found all of them except for the port side block drain....
Old 11-08-2004 | 12:28 PM
ISurvivedNMU
The port side one may be hooked to a water pressure guage..... At least they are on fountains
Old 11-09-2004 | 11:48 AM
CRD
It is a fountain, and I thought that might be it, do you disconnect the hose at the fitting or unscrew the fitting at the block?
THANK YOU
Old 11-09-2004 | 12:07 PM
Unscrew the fitting at the hose. They use a 45 or 90 fitting to go from a modified block drain plug to the hose end fitting. Put one wrench on the 45 (or 90) to hold it in place and another wrench on the fitting on the hose. It is easiest to remove the battery (on a 27 or 29 Fever) first, so you have more room to work. Otherwise it is tight working space! Also, it is a good idea to loosen the end of the hose at the gauge while you have the other end open so you can drain all of the water out of the line!
bob_t is offline
Old 11-09-2004 | 01:12 PM
CRD
Thanks for the input, very helpful!!!!
Old 09-21-2012 | 11:41 PM
Does anyone winterizing their efi sbc by running 50-1 2stroke mix?
gsickavish is offline
Old 09-22-2012 | 02:29 AM
Default fixx
yep..also run the engines in a antifreeze tank and fog the engine when running with antifreeze..
short clip so you can get a idea,,the antifreeze is polypropylene glycol.aka sierra bio.
[YOUTUBE]http://www.youtube.com/watch?v=LzDob8um5Xc[/YOUTUBE]
FIXX is offline
tcm07
10-03-2008 02:00 PM
Elite Marine
20
09-12-2008 05:28 PM
JOJO
8
09-18-2007 01:45 AM
durbin3
3
02-12-2006 03:25 PM
gsmith9898
8
10-20-2005 02:25 PM
