timing chain and cover >
Old 11-17-2004 | 06:49 PM
boatn70's Avatar
Default timing chain and cover
my short block is a new gen6 it has the OEM single row chain.
1. is this setup ok for 470-550 NA hp
2. will a double row chain fit under the cover
3. is a cam made for a double row chain any better (i havent bought the cam yet)
4. is there a reason the single is not OK
5. is the cover reusable, someone said the cover is not reusable.
thanks
kevin
boatn70 is offline
Old 11-17-2004 | 07:14 PM
Pat McPherson's Avatar
Default Re: timing chain and cover
Hey Kevin,
The ZZ502 500HP/502 uses the single roller chain.
I would think a single roller is fine unless you change to a solid lifter cam and real heavy valve springs...
Yes, the cover is reusable...
Patrick
Pat McPherson is offline
Old 11-17-2004 | 07:17 PM
boatn70's Avatar
Thanks, if anyone else has any input for me let me know.
do i have to order a cam that is compatable with the single roller chain though??
kevin
boatn70 is offline
Old 11-17-2004 | 07:35 PM
mcollinstn's Avatar
Cam doesn't care what chain you run.
Only cares whether it is for a MkIV or Gen5,6.
mcollinstn is offline
Old 11-18-2004 | 01:24 AM
Strip Poker 388's Avatar
Rob
Cloyds makes a hex a just for thegen 5-6. around 120.00.
Strip Poker 388 is offline
Old 11-18-2004 | 01:14 PM
I ordered and used a Cloyds set when I fixed my engine.
To tell you the truth, I think the Chevy High performance set looks beefier...
I plan to rebuild another GenVI this off season and I will buy the stock roller chain.
Patrick
Ran-Dom 32
Wanted
1
03-15-2008 07:06 AM
OhioRiverCigarett
7
11-13-2006 05:14 PM
tomas_wallin
7
05-26-2005 02:06 AM
kennyo
9
07-28-2004 09:21 AM
homan
2
01-05-2004 12:55 PM
