Plug trim tab hole >
Plug trim tab hole
Plug trim tab hole
Old 11-20-2004 | 10:49 PM
gripit's Avatar
Default Plug trim tab hole
I have a trs drive and on my drive shaft housing there is a plug that is described as "plug,trim tab hole". Anyway, my plugs are missing and I noticed that there is water sitting in that hole. I don't know how much water that hole holds but I am concerned about how to drain that hole. Also, what is the purpose of that hole. In the winter the water in that hole may freeze and cause damage. What should I do ? Please Advise?
HERE IS A LINK TO A PARTS DIAGRAM ITS PART #8
http://www.mercruiserparts.com/Show_...+GEAR+ASSEMBLY
gripit is offline
Old 11-22-2004 | 11:24 AM
gripit's Avatar
Default Re: Plug trim tab hole
I added a link parts diagram.
gripit is offline
Old 11-22-2004 | 03:33 PM
38KV's Avatar
Loosen the 3/8" allen screw that hold the trim anode and the water will drain.
BTW, trim the drives all the way in to get all of the water out.
The screw is located deep down in that hole.
38KV is offline
siearly
Drives and Lower Units
14
09-23-2023 06:19 PM
26sonic
04-30-2008 03:08 PM
wet_rat
Sea Ray
7
09-16-2007 04:38 AM
26sonic
Sonic
8
05-12-2006 09:23 PM
MnFastBoat
05-04-2005 08:34 AM
