ITS drive Question >
ITS drive Question
ITS drive Question
Old 12-01-2004 | 10:20 PM
2112's Avatar
Default ITS drive Question
Have ITS with XR Drives. They have an 18 inch tie bar that utilize the cap as the upper support. I want to put on a billet cap from Max Machine which does not have the uper tie bar support in the cap.
Any suggestions for rigging the tie bar?
2112 is offline
Old 12-01-2004 | 11:11 PM
Default Re: ITS drive Question
Are you using the other Max components? If not, the ITS top cap is already better than standard Bravo top caps because it uses a steel bearing support instead of the cast aluminum support. The Max stuff does look top notch. Since their cover is billet, I'll bet they could easily machine a version for the ITS, maybe they already have one or may have on in the "worx".
Falcon is offline
Old 12-02-2004 | 02:06 AM
Biggus's Avatar
I've been told the same thing.
Biggus is offline
Old 12-02-2004 | 11:02 PM
2112's Avatar
I heard this too but think it might be part of the drive shower set up. I need clarification.
2112 is offline
Old 12-02-2004 | 11:59 PM
If you really want the Worx top and can't get a version modified for the ITS, you could get the tiebar mounted using a wing plate arrangement off of the drive mounting studs. I think Latham or others may offer something because they sometimes have to offer a higher mounting for the tiebar on cats.
Falcon is offline
Old 12-03-2004 | 06:23 AM
dhlaw's Avatar
Just use a lower support....
dhlaw is offline
Old 12-03-2004 | 04:02 PM
That's a good point! With a vee and staggered to boot, all you really need is to do the trim pin saddle type of tiebar. Get a couple of standard back covers for the uppers and you should be all set.
Falcon is offline
Old 12-03-2004 | 11:35 PM
2112's Avatar
Bingo! Thanks Brett,
BTW how is the new boat compared to the yellow Boat? I assume you ae testing now.
2112 is offline
Old 12-04-2004 | 05:50 AM
dhlaw's Avatar
Today is our first day in the water... I will give you an update!
dhlaw is offline
24pantera
Drives and Lower Units
1
08-09-2007 07:58 PM
Rookie
4
05-19-2005 01:38 PM
fountain333
Pantera
19
10-25-2004 04:40 PM
Pantera24
2
04-16-2003 07:57 PM
