Rusted bolts thru transome 86 357 >
Old 12-19-2004 | 01:08 PM
Question Rusted bolts thru transome 86 357
Last summer when I had an insurance survey done the guy noticed that the bolts holding the k-planes were rusted and suggested that they be replaced after the season. These look like special bolts since on each plane one is hollow to allow the hydrolic line to pass thru. Does anyone have experience with this? They look hard to get at too. I also noticed that the bolts holding the transmission housing to the transom assembly are rusted also. What is involved with replacing these? The nature of the rusting that I refer to is the bolt heads are flaking. I am concerned that a socket won't hold.
Appreciate your help. Thank you JK
johnkot is offline
Old 12-19-2004 | 05:00 PM
Poorsche's Avatar
Default Re: Rusted bolts thru transome 86 357
I had the engines out of my boat this fall and got to see all htat stuff up close. With twins it's not possible to get to all the fastners for the K-Planes without pulling hte engines.
Those fittings for the hydraulic lines are threaded on the outside and the inside and they are expensive but seemed to made of stainless. They also serve as fastners for the K-Planes via the exterior threads, washers and bolts.
THe bolts attaching the tranny neck to the interanl gimble house are BIG steel bolts and sem to always rust--I'd get some stuff called CorrossionX and spray down that stuff unless you just can't resist pulling engines.
Poorsche
Poorsche is offline
Old 12-20-2004 | 08:20 PM
Smile Re: Rusted bolts thru transome 86 357
Poorshe,
Thank you for the reply. No, I'm not into pulling engines but it sounds like I'm out of luck here with the k-plane bolts unless I can get at them by removing the riser. Regarding the transmission bolts I'll try that stuff as long as the integrity is not compromised.
johnkot is offline
Strip Poker 388
66
06-02-2008 11:04 PM
drpete3
Drives and Lower Units
5
05-30-2008 04:32 PM
Plaineman
19
05-27-2008 10:49 AM
nocigarette
Magnum Marine
48
03-20-2007 10:54 PM
