Drive bleeds off >
Drive bleeds off
Drive bleeds off
Old 12-19-2004 | 07:25 PM
ctadams21's Avatar
Default Drive bleeds off
I did a search but surprisingly found nothing on this.
My starboard drive (Bravo 1) bleeds off (goes down) over a short period of time. It only stops when the tie bar to the port drive gets in a bind. I have to assume that it is also bleeding off while the boat is underway because I have to trim it up every so often. The hydraulic lines on the drive show no evidence of leaking. The hydraulic cylinders are clean as can be.
Any thoughts?
Thanks in advance,
Clayton
ctadams21 is offline
Old 12-19-2004 | 07:58 PM
Tricky919's Avatar
Default Re: Drive bleeds off
I have the same problem, i'm thinking the pump isn't holding pressure.........
Tricky919 is offline
Old 12-19-2004 | 08:33 PM
Poorsche's Avatar
I had same problem--in my case one of the hydraulic fittings on the manifold on the bottom of the gimble housing was not fully tight and slightest leak.
Do a search on subject or on my threads--lots of detailed suggestions there about causes and fixes
Poorsche is offline
Old 12-19-2004 | 08:59 PM
BRUCE SEROFF's Avatar
Had this problem at the beginning of the season. The pump is not holding the pressure. Time for new seals or just replace.
BRUCE SEROFF is offline
Old 12-19-2004 | 09:12 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Leaking pump relief valve or leaking ram seals. One or the other.
US1 Fountain is offline
Old 12-19-2004 | 09:20 PM
mcollinstn's Avatar
yeah.
check valve in pump
overpressure (relief) valve in pump
manual relief valve (in older round reservior pumps) leaking
piston seal in trim ram (only need one to be bad, not both).
mcollinstn is offline
Old 12-19-2004 | 09:24 PM
Tinkerer's Avatar
I have replaced the check valves in my pumps a few times.
Does anyone have a source for just the check valves instead of buying the whole rebuild kit???
Tinkerer is offline
Sick Stinger
Wanted
1
03-16-2008 09:54 PM
Canada Jeff
Drives and Lower Units
10
07-19-2007 02:38 PM
thayes11
0
10-02-2005 12:36 PM
Velocity Tom
07-16-2003 10:13 AM
panteraracin
3
02-07-2002 10:36 PM
