OMC guys... new question. Shifters. >
Old 12-21-2004 | 11:36 AM
fund razor's Avatar
Default OMC guys... new question. Changing shifters to Livorsi style.
Ok, considering leaving my points in the boat per the other thread.
New question:
I would rather have separate control levers for throttle/shift.
How hard would it be to switch. Could I possibly use my existing cables?
fund razor is offline
Old 12-21-2004 | 11:37 AM
fund razor's Avatar
Default Re: OMC guys... new question. Shifters.
I caught your response on the other thread Ted.
Thanks.
Old 12-21-2004 | 11:47 AM
fund razor's Avatar
The OMCs have a two piece cable.
Can I just replace the forward half?
Old 12-21-2004 | 12:25 PM
Doller Offshore
if you're using a 33c style cable you can reuse them,if they are omc cables you cannot.if you plan on using a livorsi/gaffrig control it might cover the old hole.
Old 12-21-2004 | 01:03 PM
fund razor's Avatar
I have the "new" OMC (red jacket) cables that were a past warranty issue.
Can I replace the forward half of the cable, but stop at the trunion located on the shift bracket, and use the OMC cable out the transom?
(They're Cobras)
Old 12-21-2004 | 01:11 PM
fund razor's Avatar
I was gonna use Livorsi style controls if I can.
My current controls mount to a plate that covers the actual "hole."
Worst case scenario I could fabricate a new plate.
I'm just curious how extensive the overall project will be, and how far back I have to go with the new cable and still have everything balance out tension wise.
The adjustment on the existing cable is on the transom bracket. You don't adjust it at the trunion.
Old 12-21-2004 | 02:28 PM
fund razor's Avatar
ttt
Old 12-22-2004 | 08:33 AM
fund razor's Avatar
Can I stop at the shift cable trunion on the bracket? Doesn't seem like you would have to do the rear half if the forward half is right.
Tantrum
04-12-2005 12:13 PM
CC247
2
04-01-2005 11:54 AM
fund razor
15
12-22-2004 08:27 AM
razor1115
4
03-25-2004 11:13 PM
Shorgasm
03-09-2002 08:58 AM
