Low Mount Alt. & P/S Pump Location >
Old 12-27-2004 | 08:16 PM
Panic Button's Avatar
Emerald Coast of Florida
Default Low Mount Alt. & P/S Pump Location
Any ideas on mounting brackets for the Alternator and P/S pump. Motor is BBC (Dart block, single engine) with CMI's. The stock brackets hit the headers. I've found the low mount alternator bracket, but who makes a power steering pump bracket that will relocate the pump and/or where to relocate the pump. The motor will be running "V" belts, and the stock Merc sea water pump in stock location.
Thanks-
Chris
Panic Button is offline
Old 12-27-2004 | 08:25 PM
rbtnt's Avatar
Default Re: Low Mount Alt. & P/S Pump Location
Do the brackets hit the CMIs or just the PS pump? I run the v-belts with my CMIs and used a shorter PS belt to move the PS pump.
I think IMCO has something that might work.
http://www.imcomarine.com/pages/performance.html
I would try Trick Marine or CP Performance as they are advertisers here.
rbtnt is offline
Old 12-27-2004 | 09:12 PM
Stock Merc bracket causes the alt. to hit the headers and the water feeds. I looked at the IMCO bracket for the alt. but they don't make one to reposition the P/S pump. The P/S pump is a Saginaw.
Old 12-28-2004 | 07:51 AM
I had the same problem with my CMI Sport Tubes. I got an IMCO low mount P/S / Alt. bracket and it works very well.
Craig
WETTE VETTE is offline
DesertRage
Swap Shop
5
10-13-2008 08:29 PM
superwrench0166
Drives and Lower Units
1
08-07-2007 08:34 AM
SCANDINAVIAN
0
06-10-2007 03:39 PM
Panic Button
6
02-05-2005 06:18 PM
traviss
6
12-22-2002 10:39 AM
