How do you remove odors from foam padding? >
Old 12-28-2004 | 10:22 AM
pachangalpina's Avatar
Default How do you remove odors from foam padding?
I am recovering a set of bolster seats for my Fountain and have removed the vinyl to get to the wood forms that need to be rebuilt. I am saving the sculpted foam because it is in good condition but has a musty moldy smell. What is the best way to deodorize it before I reattach it to the forms?
Thanks, Todd
pachangalpina is offline
Old 12-28-2004 | 11:17 AM
Crazyhorse's Avatar
Default Re: How do you remove odors from foam padding?
Take the foam with you on New Year's Eve and let it absorb the smoke from all the smokers in the bar.
Crazyhorse is offline
Old 12-28-2004 | 02:27 PM
fund razor's Avatar
In all seriousness, I have had limited good luck with febreeze.
But you need to be sure that there aren't any living cooties. Maybe spray em with lysol or something, or wipe them with something, THEN febreeze.
Then let them air out awhile, then more febreeze.
fund razor is offline
Old 12-28-2004 | 03:10 PM
Sunlight and Fe-Breeze should do the trick. Maybe attempt a mild mix of bleach and soak them and spin dry in wash machine first. Try a test spot to see if it deteriorates the material first. You may call Knox Foam and see if they have any ideas. Another shot would be to try one of the fire restoration companies in the yellow pages and see if they have any ideas.
http://www.knoxfoam.com/cgi-bin/SoftCart.exe/?E+scstore
BadDog is offline
Old 12-28-2004 | 03:52 PM
robyw1's Avatar
One wash in a washing machine on a delicate cycle should do the trrick.
Roby
robyw1 is offline
Old 12-28-2004 | 06:43 PM
Thanks, guys.
onesickpantera
Sonic
10
08-26-2008 07:31 PM
onesickpantera
08-25-2008 06:50 PM
Poorsche
08-16-2005 06:24 AM
Bill 3
05-09-2005 03:13 PM
offthefront
06-11-2004 01:10 PM
