water pressure >
water pressure
water pressure
Old 01-09-2005 | 02:06 PM
baja36ft's Avatar
Default water pressure
What should be the water pressure if there is no stat and no water pump(just a sea water pump) and a cross over i tap the water gauge to the cross over? i have 25psi now is that to much?? at wot.
baja36ft is offline
Old 01-09-2005 | 03:07 PM
RLW
Default Re: water pressure
In my mind, 25 psig is the limit at WOT. I have a Mercury Racing pressure relief valve on my engine and the most I see is 22 psig. It is the spikes that you have to be concerned with. The PRV that I use pretty much addresses that issue.
Russ
RLW is offline
Old 01-09-2005 | 03:25 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I'm surprised you get that much w/o a t-stat installed. You might find the pressure a bit lower if you tapped into the block itself, eliminating the resistance from the 2 crossover to block holes.
US1 Fountain is offline
Old 01-09-2005 | 04:55 PM
baja36ft's Avatar
I thought it was a little high i was gonna put in water dumps to lower it.
i do have gil exhaust.
baja36ft is offline
Old 01-10-2005 | 12:31 AM
Take a pressure reading form the engine block to get an accurate reading.
Griff is offline
LostinBoston
18
03-26-2006 07:23 AM
BOATMAN302
3
02-28-2006 08:17 PM
Zanie
5
03-10-2005 10:58 AM
28Eliminator
11
06-22-2004 10:43 PM
merlin540
08-28-2002 05:45 PM
