Forged or hypereutectic pistons? >
Old 02-13-2005 | 10:00 PM
phughes69's Avatar
Default Forged or hypereutectic pistons?
I pulled my motor apart tonight and found the top ring land gone on one piston. Now I have to figure out what kind of pistons to run. The motor will be a 468 with cast iron rectangular heads and twin turbos running about 10 psi of boost. Should I consider running a hypereutectic piston at this boost level. The inital compression with the hypereutectic pistons will be about 7.5
phughes69 is offline
Old 02-13-2005 | 10:09 PM
Biggus's Avatar
Default Re: Forged or hypereutectic pistons?
I'd run nothing but forged pistons.
Isn't 'Hypereautectic' just a fancy word for a cast piston with a high silicon content?
I like to build them with the best parts so you can feel good about it when you have the throttles mashed to the dash
more .02
Kurt
Biggus is offline
Old 02-13-2005 | 10:21 PM
Forged all the way. All Hyper. pistons are good for is dissipating heat faster, but at a cost of strength. Forged pistons are denser therefore hold heat longer, but take more abuse.
NOBODY is offline
Old 02-13-2005 | 11:08 PM
I broke one of those pieces of crap on an under 100 hour 454 rebuild. I will never have that problem again! Forged only.
BGIII is offline
Old 02-14-2005 | 07:34 AM
mcollinstn's Avatar
you want forged turbo pistons with extra thick top lands.
mcollinstn is offline
Old 02-14-2005 | 08:03 AM
dykstra's Avatar
Forged
dykstra is offline
Old 02-14-2005 | 08:35 AM
mikes280's Avatar
forged is the only safe way to go and i would get a peice made for usng a turbo spend the money now and you won't regret it
mikes280 is offline
BadDog
10
05-19-2006 06:20 AM
QUIKDECISION
27
05-07-2005 04:35 PM
QUIKDECISION
6
04-30-2005 10:38 PM
JLS
2
10-23-2004 10:21 AM
FASTERDAMITT
06-02-2004 08:26 PM
