Go Back  Offshoreonly.com > Owners Forum > Donzi
38 ZR Comp speed >
38 ZR Comp speed
38 ZR Comp speed
Old 03-04-2005 | 11:21 PM
MikaylaHunterCig's Avatar
Default 38 ZR Comp speed
What should the top speed be on a 500 efi powered 38 zr ?
MikaylaHunterCig is offline
Old 03-05-2005 | 08:59 AM
Shanghied Again's Avatar
Registered User
Default Re: 38 ZR Comp speed
The ZR Competition should be running mid 80s.
Shanghied Again is offline
Old 03-05-2005 | 01:58 PM
sellsman11's Avatar
He hit it on the head. 85 - 86.
sellsman11 is offline
Old 03-05-2005 | 05:19 PM
So i am about 5-6 miles and hour off...
Any advice ?
Old 03-07-2005 | 12:26 PM
Buy our 38. You'll still be off about 15mph., but it'll be to the plus side.
JW
JWilmoth is offline
Old 03-07-2005 | 12:28 PM
Correction... about 25mph. Sorry about that, I was feeding the dog and trying to add at the same time.
JWilmoth is offline
Old 03-09-2005 | 10:10 PM
SHORELINE MARINA's Avatar
my stock 2003 38 zr with 575 runs 97 gps!
SHORELINE MARINA is offline
Old 03-11-2005 | 12:26 AM
I am running 32p bravo's( no lab)@5,000 = 80mph
Still need 5mph to be where i was told the boat should run.
Old 03-11-2005 | 11:27 PM
ZR
[COLOR=Red]You should have the props checked out and lab finished. Make sure the props match up. You need to free them up to get at least 5200+ rpm. Just the slightest vibration or un-true blade will make a difference. Also make sure you are not over trimming your ZR. my ZR runs its fasted @4.0 to 5.0 on the trim gauge.
I bought my ZR used like you did and I could only get 87mph @ about 4950 rpm w/ 525efi. I sent the props out and the prop guy said the blades were very dirty. He also said they were a little mis matched and a couple others things I can't remember.
When I got the props back the boat went right up to 92mph @5250 RPM
Good Luck
ZR
undefined
ZR is offline
Old 03-20-2005 | 10:03 AM
OK, Props are out being labbed so i hope to see a magic number next weekend.
Thanks for all the advice - i'll keep everyone posted.
Dave
