2005 28' w300's Balancing Issue >
Old 11-18-2005 | 04:49 PM
Default Re: 2005 28' w300's Balancing Issue
do you have any pictures of external pickups and whos are they.what kind of pressure and are they plumbed to exhaust plate or waterpump.
thanx
Loef is offline
Old 11-19-2005 | 11:35 AM
Havasu Cig's Avatar
The pick-ups were made and installed at LakeLand Marine in havasu. They are the outboard guru's out here. They are plumbed through the bottom of the boat in front of the drain plugs with check valves inside the bilge.
The check valves allow the pick-up's on the motors to work until you have enough speed to open the valves. The external pick-up's are not plumbed to a water pump. They make pressure from the speed of the boat.
I am seeing about 10 pounds of pressure at 80 mph and about 15 pounds at 115 mph. I was concerned that the pressure was a little low but lakeland says as long as the smart craft is not going into protective mode, or giving an alarm the pressure is fine. The motors run nice an cool as well so I think they are probably right.
I will take some pic's of the Pick-up's later today when i get home.
Havasu Cig is offline
Old 11-22-2005 | 07:48 PM
Havasu Cig's Avatar
Here are some pic's of the pick-up's. I still can't get the video to work.
Attached Thumbnails 2005 28' w300's Balancing Issue-dsc00411-small-.jpg   2005 28' w300's Balancing Issue-dsc00413-small-.jpg   2005 28' w300's Balancing Issue-dsc00414-small-.jpg
Old 11-22-2005 | 07:50 PM
Havasu Cig's Avatar
Some more...
Attached Thumbnails 2005 28' w300's Balancing Issue-dsc00412-small-.jpg   2005 28' w300's Balancing Issue-dsc00415-small-.jpg   2005 28' w300's Balancing Issue-dsc00411-small-.jpg
Old 11-22-2005 | 10:47 PM
Ryan Beckley's Avatar
Racer
Racer
The H2O pickup could be shaved half that size and you'll pick up speed.
Ryan Beckley is offline
Old 11-23-2005 | 12:22 AM
Semper Fi's Avatar
Havasu Cig's Skater rocks! I love that boat. I was with him on Lake Elsinore a few months ago and we ran 112 before he got the boat dialed in.
Semper Fi is offline
Old 11-23-2005 | 03:32 PM
I agree with ryan .are you turning in or out.are you running racehatch with seat removed.if not you may want to try.
Loef is offline
Old 11-24-2005 | 07:43 PM
Havasu Cig's Avatar
Ryan,
Lakeland told me the same thing about the pick-up's, but they wanted to leave them long and run the boat then cut them down once we know there are no problems. They are telling me shaving them down is probably good for a mph or so...
Loef,
the props are spinning out and the back seat (as well as a cooler) was in the boat when I ran 117 mph. I want to try a race hatch...
Old 12-16-2005 | 03:08 PM
TeamSaris's Avatar
Driver-441
Racer
Originally Posted by jschw80141
Question I have heard the the 28' was designed with 2.5's and the 300's weight throws off the balance of the boat. How could I determine if the boat is well balanced?Dont want to find out the hard way- Does this make the boat potentially more dangerous then other cats with 300's?
Any insight would be appreciated?
MY friend has a 28 with 3 2.5's/ Runs 125. Its the old king sting, set hudson river record.
TeamSaris is offline
JO - PANTERABOATS
Pantera
26
10-21-2005 01:11 PM
russ
0
07-21-2005 04:35 PM
JO - PANTERABOATS
06-26-2004 07:03 AM
JO - PANTERABOATS
Pantera
48
05-06-2004 09:34 PM
