Turbine 101
#413
look at pic's below they were the eng we were running
750 hp merc racing efi with brodix heads. torque was 675lbs
the drives are 4,s with 5 shafts. they were freshined up at psa marine 510 865 4191
questions call paul @psa(throttle man) or mike reb, plat member mikiedreb (navagater)
both helped build this boat.
barry
barry
#416
Notice the Polished forward scoops. this will capture fresh cool
air and force it in the engine bays. This should allow for a cooler engine bay.
The air will exit at the rear of the stern via billet vents.
#418
Ok here we go!
I Red Scotch brite the hatches before anything.
Then Washed them with prep sol.
The green tape lines (Fine Line) stays down all thru the painting. Then I will pull them before the clear.
I put down a violet base then sprayed the Tropical blue.
#419
ROCK ON !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
#420
I picked up a 100 dollar Airbrush at Bear Air.
It looks like Steve at EGO used Black for the drop shadows.
He is suppose to stop by and check up on me.
By the time he gets hear I will have screwed it all up
I also sprayed some swatches so I could match it closer.
Its alot harder to match when your not blending into ajacent
panels.
Considering I,m a monkey with a airbrush I figured I better practice.
panels.
